Hi, I'm in need of some help. I'm assuming I got the right info for you:
Product Version - 15.0 Product Update 6 Student.
3ds Max - 2013 x64
Renderer - Mental Ray
Lighting - Mr Sun and Mr Sky (mr Photographic exposure control)
PROBLEM: I don't use Hair and Fur much, and I'm also an amateur, so I have no idea what's going on. I set the Hairs to Mr Prim or whatever you call it and now I'm getting white reflective like spots. Does anyone know what's happening here? I've looked around a bit, haven't seen anyone with this problem before.
Ignore my silly Cypress Tree cutouts and my ugly wintery background...
If i left out anything let me know!
Solved by Brock_Lafond. Go to Solution.
It looks like it might be a material issue. Can you render the hair seperately in scanline and composite it after?
When you render our the hair layer for compositing, save out the image with an embedded alpha. That will take care of the masking for you.
If using Photoshop to composite, go to the alpha channel and do a ctrl+click or command+click (Mac) on the channel. It will select the hair pixels for you. Invert the mask and delete the rest of the pixels or apply the selection to a layer mask.
Sorry for the delay, I went away for a few days.
I'll play around with it in Photoshop. The only thing I'm worried about is when rendering the Hair and Fur without Mr Prim, the hairs don't have shadows cast on them. At least, that's what was happening before I set it to Mr Prim... I'll figure it out.
I'm gonna go ahead and assume this is a material issue like you suggested. Thanks for the help!
I GOT IT!
The problem I was having kept me from working on this any further, but I came back to it. I played around with the Hair and Fur settings a bit and took interest in the two white boxes found in the Materials Parameter. Well obviously the issue I'm having was with white spots appearing on my Fur, and it turns out it was the Specular Tint (second white box) that was giving me trouble. I changed it to green and it blends right in with my grass.
The Specular Tint is now green instead of white.
I'm usually frustrated when people find an answer to something and don't post how they fix it, so this is for anyone who stumbles across this and has the same issue.
