3ds Max Shading, Lighting and Rendering
Welcome to Autodesk’s 3ds Max Forums. Share your knowledge, ask questions, and explore popular 3ds Max materials topics.
How to light a streetlight
11 REPLIES 11
Message 1 of 12
alan.r.stewart56
965 Views, 11 Replies
alan.r.stewart56
Hi. I'm driving myself crazy with what (to most of you) will seem a very minor problem. Essentially, I am trying to create a night scene, in which I want to use a very nice model of a Victorian gas streetlight. I've tried various solutions, the latest being VRay sphere lights inside each of the four lamps mounted on the post. As you'll see from the image below, they are casting light on the ground below, but the lamps themselves appear totally dark. The second image below shows the texture files used in the streetlight model - if you examine the Opacity map, you will see that there appear to be black panels at lower left which I assume correspond to the glass panes of the model's hexagonal lamps. As I understand it, in an Opacity map black equals transparent, but perhaps that is incorrect.
I should mention that I'm a self-taught amateur, not an industry professional, so I would really appreciate any pointers which you guys can give. Thanks in advance.......
11 REPLIES 11
Message 2 of 12
CiroCardoso3v
Can you share that asset, so that I can have a look? Also, which vray version are you using?
Lead Enviroment Artist @Axis Studios
Arnold Discord Server
Ciro Cardoso
Ciro Cardoso
Message 3 of 12
alan.r.stewart56
<meta http-equiv="Content-Type" content="text/html; charset=utf-8" /><meta name="Generator" content="Microsoft Word 15 (filtered medium)" /><!--<br>/* Font Definitions */<br>@font-face<br> {font-family:"Cambria Math";<br> panose-1:2 4 5 3 5 4 6 3 2 4;}<br>@font-face<br> {font-family:Calibri;<br> panose-1:2 15 5 2 2 2 4 3 2 4;}<br>/* Style Definitions */<br>p.MsoNormal, li.MsoNormal, div.MsoNormal<br> {margin:0cm;<br> font-size:11.0pt;<br> font-family:"Calibri",sans-serif;}<br>a:link, span.MsoHyperlink<br> {mso-style-priority:99;<br> color:blue;<br> text-decoration:underline;}<br>.MsoChpDefault<br> {mso-style-type:export-only;}<br>@page WordSection1<br> {size:612.0pt 792.0pt;<br> margin:72.0pt 72.0pt 72.0pt 72.0pt;}<br>div.WordSection1<br> {page:WordSection1;}<br><br>
Message 4 of 12
CiroCardoso3v
I think you may have to check the message above.
Ciro Cardoso
Ciro Cardoso
Message 5 of 12
alan.r.stewart56
That's weird. I was trying to link to OneDrive so you could access the files easily. Clearly that didn't work.
Here is the fbx file, plus the first two texture files (this platform only allows three files at a time to be sent). The rest will follow asap.
Message 6 of 12
alan.r.stewart56
Files 3,4 and 5
Files 3,4 and 5
Message 7 of 12
alan.r.stewart56
Files 6.7 and 8
Files 6.7 and 8
Message 8 of 12
alan.r.stewart56
And the last one. You'll see that there are two sets - one is for the base & pole, the other is for the lantern sections.
I would have prefeered to send you the .max file, but this is about 3x the maximum file size allowable..
Message 9 of 12
wernienst
Maps are ok I think (light_street light pole_Metallic.png is missing). Since I don't own Vray, I replaced the light dummies by Arnold Point lights.
Message 10 of 12
CiroCardoso3v
Sorry, I have been away. I will have a look at this.
Ciro Cardoso
Ciro Cardoso
Message 11 of 12
CiroCardoso3v
OK, so here it goes. Hope this helps
And the file is attached
https://we.tl/t-hwgQWoDgsN
Ciro Cardoso
Ciro Cardoso
Message 12 of 12
alan.r.stewart56
That's looking really good - thanks for all your efforts!
