Announcements
Physical Material and alpha map cutout
mphillipsESTPB
mphillipsESTPB
Hi Everyone,
I am having trouble mapping a leaf to a plane surface. I created an alpha channel map and applied the bitmap as a cutout and have my leaf texture as my base color. However when I render using Arnold my leaf has a slight transparency which I cannot get rid of. Please help !
Replies (7)
CiroCardoso3v
Can you save one of the leafs with the material and upload it here? Will be easier to explain how it works.
Lead Enviroment Artist @Axis Studios
Arnold Discord Server
Ciro Cardoso
mphillipsESTPB
See attached file and Images.. Thank you in advance for your help!!
CiroCardoso3v
OK, so I had a quick look. What you need is a diffuse map and a opacity map. Isn't a good idea using a psd file as your texture, as this can't be converted to TX files, and is also introducing some opacity errors.
So, connect a png\jpg\targa file as a diffuse map and the same for the opacity.
Ciro Cardoso
mphillipsESTPB
I was using a .tga map as my diffuse bitmap. However It still makes the leaf semi transparent. when rendering.
Stephen.Blair
I would use a non-PSD texture for the opacity map too.
What PSD layer did you use? I took the individual layer Layer 1, and the alpha was 1 everywhere.
// Stephen Blair
// Arnold Renderer Support
mphillipsESTPB
These is the diffuse map I utilized when rendering the leaf. The other was a tga map (I cannot upload to this chat) which you can generate from the previous .psd file I shared. If you can generate your own .tga file and try to render.
Stephen.Blair
I don't have anything for editing psd files
But by using an individual layer from that PSD, I did get opacity (I changed the base color to a flat color, no texture)
// Stephen Blair
