3ds Max Shading, Lighting and Rendering
Welcome to Autodesk’s 3ds Max Forums. Share your knowledge, ask questions, and explore popular 3ds Max materials topics.
How to keep material in Revit? Revit Interoperability for 3DS Max
7 REPLIES 7
Message 1 of 8
travis.designer.vn
1004 Views, 7 Replies
Hi
When I use Revit Interoperability for 3DS Max to bring model to 3DS Max. I add material and texture in Revit.
Use default Arnold rendering. They show error. How can I fix it?
Below picture is rendered in Revit 2021.
7 REPLIES 7
Message 2 of 8
Are there anyone use Revit Interoperability for 3DS Max?
Message 3 of 8
Change your render engine to ART, its more compatible with revit materials.
Richard Vivanco V.
Arq. BIM Manager + Autodesk Certified Instructor
Website | Youtube | LinkedIn
Message 4 of 8
Hi @Richard.Vivanco
I agree with you. I change to ART Render.
And This is message when I use ART Rendering:
Do you have any suggest to improve it?
Message 5 of 8
ART have limitations, its a basic render engine and dont recognize a lot of maps, like speckle for example.
Select this two material and disconect the speckle material or replace it with a jpg file.
Richard Vivanco V.
Message 6 of 8
Thank @Richard.Vivanco
Message 7 of 8
in reply to: travis.designer.vn
Hi Travis Nguyen,
You could also try in the render setup, as the arnold render engine is chosen,
In the system tab tic the option: Legacy 3ds max map support.
That might help arnold recognise your maps.
I hope that would be helpful to you.
Message 8 of 8
in reply to: Richard.Vivanco
@Richard.Vivanco  hi may i know how can i disconnect the speckle?
