Hi
When I use Revit Interoperability for 3DS Max to bring model to 3DS Max. I add material and texture in Revit.
Use default Arnold rendering. They show error. How can I fix it?
Below picture is rendered in Revit 2021.
Solved by Richard.Vivanco. Go to Solution.
I agree with you. I change to ART Render.
And This is message when I use ART Rendering:
Do you have any suggest to improve it?
Hi Travis Nguyen,
You could also try in the render setup, as the arnold render engine is chosen,
In the system tab tic the option: Legacy 3ds max map support.
That might help arnold recognise your maps.
I hope that would be helpful to you.
