Hiii, I'm having problems with a short 64 frame animation I'm rendering out of 3DS Max/Arnold Renderer. The first and last set of frames are not properly rendered while the middle frames seem to be just fine. On a second try with a simpler animation path, all of the frames come out unrendered. I also attached a recording of my rendering setup and how it looks like in the render preview. What's wrong and how can I fix this? Thanks!
It looks like the precalculation frames that are used to interpolate the frames that come affer them. What happens if you set the start to -10 and the end to 10 frames longer? I think if you do, you can have full and nice renders for your '0' to 'End' timeline.
Rob Holmes
------------------------------------------------------------------------------------------------------------------------------------------Any chance you can share this scene with the settings? Something doesn't feel right.
