Hiii, I'm having problems with a short 64 frame animation I'm rendering out of 3DS Max/Arnold Renderer. The first and last set of frames are not properly rendered while the middle frames seem to be just fine. On a second try with a simpler animation path, all of the frames come out unrendered. I also attached a recording of my rendering setup and how it looks like in the render preview. What's wrong and how can I fix this? Thanks!
It looks like the precalculation frames that are used to interpolate the frames that come affer them. What happens if you set the start to -10 and the end to 10 frames longer? I think if you do, you can have full and nice renders for your '0' to 'End' timeline.
Rob Holmes
Any chance you can share this scene with the settings? Something doesn't feel right.
