3ds Max Shading, Lighting and Rendering
Welcome to Autodesk’s 3ds Max Forums. Share your knowledge, ask questions, and explore popular 3ds Max materials topics.
hair and fur not render with materials in 3dsmax 2015-
10 REPLIES 10
Message 1 of 11
Richard.Vivanco
5391 Views, 10 Replies
Hi
In max 2015 i have a problem when i use hair and fur.  For example, i have a plane with blue color , then apply hair and fur, when i render  the hair appears blue not with the brown/yellow colors that have by default.  if i put a material to the plane, then the hair and fur appears with the diffuse color of the material.
I remember in previous version that the colors of hair and fur are controlled by the material parameter (tip,root) or you have the option to put a map to control the color.
I change to traditional classic/raytraced,  dissable DBR, render not in ortographic view.. but the problem persist.
Any idea?
Richard Vivanco V.
Arq. BIM Manager + Autodesk Certified Instructor
Website | Youtube | LinkedIn
10 REPLIES 10
Message 2 of 11
I try to load a hair and fur preset, but i have the same problem....
Richard Vivanco V.
Message 3 of 11
in reply to: Richard.Vivanco
Did you manage to solve this problem? I'm having the same issue and it's driving me crazy.
Message 4 of 11
Hi, you need to change the hair and rendering options to mr prim, like my screenshot.
Message 5 of 11
That actually made the fur completely dissapear. I'm also able to render the fur in any viewport. to my understanding it should only render in cameras/perspective.
Message 6 of 11
Allright, i'm an idiot. fixed it though. thanks!
Message 7 of 11
Hi, shouldn't make the fur disappear.
I just create a simple plane, add hair and fur modifier, select "mr prim" in effects settings and here's the result.
And yes, you can render hair and fur with orthographic cam, and perspective cam of course.
mr prim selected:
Buffer selected:
Message 8 of 11
Yes thank you. I fixed it and buffer works as well, it was a stupid mistake. my default renderer was the quicksilver hardware renderer.
Message 9 of 11
This solution solved my problem with Mental Ray, but problem still presists in Iray... Will Iray do Hair and Fur?
Iray
MrPrim = disapears
Geometry = no color
Buffer= no color
Message 10 of 11
same results for me. I've tried multiple solutions but haven't found anything yet.
Message 11 of 11
For iray, you will need to use Geometry. For the material, you can use the object material and hide the geometry. And use a copy of this geometry (without the hair and fur modifier) as the main object with a different material.
Or you can convert your hair to mesh and apply your material to the new hair mesh.
Technology Administrators
