My shaded material don´t work, and i don´t understand why!! i alredy try to unistall and install again the program, and the problem continuous to happen.
can anyone help me?
Ana
It looks like you are in wireframe mode which does not display any materials - press F3 again to get back default shading mode - or click on "[wireframe]" in top left of viewport and select one of the other options.
This video may help - https://www.youtube.com/watch?v=J1atceGFdNo
Post back if you continue to have trouble.
Daf
Sorry I don't understand - can you upload a simple scene that illustrates the issue?
Daf
Okay - let's see if it's going to be easy - maybe you are in X-ray mode. Try pressing alt+x and see if that helps. If not it could be a graphics driver issue. What graphics card and driver are you using?
i use 3dmax a lot, and this is the second time that hapen. i have to format the pc fot the program run normally, without this error.
Intel(R) Core (TM) i5-320M CPU @ 2.5GHz
RAM 6 Gb
sistem 64 bits
windows 7
Seems like it may be a graphic driver issue - I'm afraid I'm not going to be much help with that - hopefully someone else can jump in. Sorry I can't be more help with this. 😞
Daf
Try changing your display driver.
Use a direct3D 9 or one of the Legacy drivers to see if it changes anything
You can also get to this by going to Customize, Preferences, viewports, Choose Driver.
No necesitas ir al extremo de formatear la pc , por que no es de la pc ni la grafica, si no del mismo 3d max el error, por lo cual basta con borrar el archivo de 3dsmax.ini alojado en la ruta de disco local C/ usuario/ appdata/ local/ autodesk /3dmax "version" / y ahi abajo esta el archivo que te dijo con terminacion . ini al borrarlo y al abrir 3ds max se iniciara como si lo abrieras por primera vez ..
