3ds Max default shading issue
i have a issue in view as a default shading i'm try to change the display card and change the driver and change the operating system and change 3dsmax and the same result .. any one can help?!
Replies (9)
Francisco_Penaloza
I don't understand what's your problem here, Is the way the viewport displays?? Lights/ Shadows?
First, you have many options to showcase your display.
Just go to the small text menu on the top left corner of your viewport, then you can choose a different way to display your viewport. Wired, Shaded, Flat ETC.
Now all these styles will depend on what render engine you are using, IF it is V Rya then you options are limited, But most of them work fine.
just i wont to see this file like the this view as a default shading "in attached image" on this replay
hope that can explain what the problem 🙂
i don't have more experience on Designs programs but i working as IT engineer and our users faces this problem
hope if u can help.
Francisco_Penaloza
okay i'll try with different way to display my viewport as your first post, hope it solve and i'll reply to u
thanks 4 help
you mean this menu ?! @Francisco_Penaloza
I have this problem too
i resolve this problem .. but i think you have a different one
anyway let's us try
what your graphic card model ?!
Nvidi gtx 750
arqvisuart
Observer
Observer
Es mas facil que te vayas a la carpeta de 3d max y busques un archivo con terminacion . ini lo borres y al abrir 3d max  nuevamente se reconfigurara a fabrica y listo  . ojo que teiens que activar la casilla de ver elementos ocultos para entrar a la ruta de appdata..
