3ds Max Shading, Lighting and Rendering
Welcome to Autodesk’s 3ds Max Forums. Share your knowledge, ask questions, and explore popular 3ds Max materials topics.
F3 shading viewport problem
13 REPLIES 13
Message 1 of 14
1712 Views, 13 Replies
My shaded material don´t work, and i don´t understand why!! i alredy try to unistall and install again the program, and the problem continuous to happen.
can anyone help me?
Ana
can anyone help me?
Ana
13 REPLIES 13
Message 2 of 14
Daf
Daf
It looks like you are in wireframe mode which does not display any materials - press F3 again to get back default shading mode - or click on "[wireframe]" in top left of viewport and select one of the other options.
This video may help - https://www.youtube.com/watch?v=J1atceGFdNo
Post back if you continue to have trouble.
Daf
3DS Max 2020.3
i7-4790 @4GHz • 32GB • GTX 1080/8GB • Windows 7 Pro
Daf
3DS Max 2020.3
Message 3 of 14
in reply to: Daf
Don t work the shaded... The shape desaper. That s why the shape is in
wireframe. Because doesn't appear on shaded
Message 4 of 14
Daf
Daf
Sorry I don't understand  - can you upload a simple scene that illustrates the issue?
Daf
3DS Max 2020.3
Daf
3DS Max 2020.3
Message 5 of 14
in reply to: Daf
on the photo number 1 i have a box in wireframe, and the photo number 2 is
the same box but in shaded. doesn´t apear anithing.
Ana
Ana
Message 6 of 14
Daf
Daf
Okay - let's see if it's going to be easy - maybe you are in X-ray mode. Try pressing alt+x and see if that helps. If not it could be a graphics driver issue. What graphics card and driver are you using?
3DS Max 2020.3
3DS Max 2020.3
Message 7 of 14
in reply to: Daf
Message 8 of 14
in reply to: Daf
i use 3dmax a lot, and this is the second time that hapen. i have to format the pc fot the program run normally, without this error.
Intel(R) Core (TM) i5-320M CPU @ 2.5GHz
RAM 6 Gb
sistem 64 bits
windows 7
RAM 6 Gb
sistem 64 bits
windows 7
Message 9 of 14
in reply to: Daf
i tried that solution, alt+x and nothing happen
Message 10 of 14
Daf
Daf
Seems like it may be a graphic driver issue - I'm afraid I'm not going to be much help with that - hopefully someone else can jump in. Sorry I can't be more help with this. 😞
Daf
3DS Max 2020.3
Daf
3DS Max 2020.3
Message 11 of 14
in reply to: Daf
thanks anyway 😞
thanks anyway 😞
Message 12 of 14
Try changing your display driver.
Use a direct3D 9 or one of the Legacy drivers to see if it changes anything
You can also get to this by going to Customize, Preferences, viewports, Choose Driver.
Message 13 of 14
it works now, with the direct3d 9 🙂 thanks so much
Message 14 of 14
arqvisuart
arqvisuart
Observer
Observer
No necesitas ir al extremo de formatear la pc , por que no es de la pc ni la grafica, si no del mismo 3d max el error, por lo cual basta con borrar el archivo  de 3dsmax.ini  alojado en la ruta de  disco local C/ usuario/ appdata/ local/ autodesk /3dmax "version" /  y ahi abajo esta el archivo que te dijo con terminacion . ini al borrarlo y al abrir 3ds max se iniciara como si lo abrieras por primera vez ..
