3ds Max Shading, Lighting and Rendering
Welcome to Autodesk’s 3ds Max Forums. Share your knowledge, ask questions, and explore popular 3ds Max materials topics.
Activeshade missing from viewport
4 REPLIES 4
brian
1485 Views, 4 Replies
brian
Hello, I've been able to use activeshade in the viewport, but suddenly I can't.
Target set to Activeshade
Renderer - Arnold
Floating activeshade window works perfectly
There is no option in the viewport pulldown for activeshade
If I got to viewport configuration/layouts, I can change the viewport to activeshade, but this results in a black screen with the pull-down windows normally in that window no longer available.
Latest MaxtoA version
Graphics driver looks correct (and active shade floating works)
Restarted/rebooted, changed screen resolution etc
I'm not sure what I hit or did to have the option removed.
I've included a screen recording with a simple scene.
Thanks for any help!
Renderer - Arnold
4 REPLIES 4
in reply to: brian
Hi ..
if you need pulldown for activeshade and change it to perspective again
apply the same way but in the other windows .. click on [ + ]  ... the same window will appear then change the activeshade to perspective again 🙂
If you need something else please explain 🙂
Hi ..
brian
brian
This doesn't work. The viewport is already perspective.
Activeshade is not available in any of the viewports under the pull-downs.
I know where it should be, but it isn't.
in reply to: brian
I found it. it's different from 3ds max 2017. I guess you are using 3ds max 2020 like me...
It's not under the 2nd (physical  cam) but the third brackets (standard) : [+][physicalCam][standard][default...]
Hope it helps.
Hope it helps.
Thank you for this!
Thank you for this!
