3ds Max Programming
Welcome to Autodesk’s 3ds Max Forums. Share your knowledge, ask questions, and explore popular 3ds Max SDK, Maxscript and Python topics.
How to check overlapped UVW faces in specific map channel?
10 REPLIES 10
Message 1 of 11
LayTiger
648 Views, 10 Replies
I tried xView "OverlappedUVWFaces.Check" first, but the function will return all overlapped uvw faces throughout all map channels.Then I found that "Select Overlapped Polygons" button in the UVW editor works well, so I tried to use the function to get overlapped uvw faces, but it seems not work in my code. Can somebody please help me?
fn CheckOverlappedUVWInSecondUV geo=
	local unwrapMod =  geo.modifiers["Unwrap_UVW"]
	local overlappingUVWFaces = #{}
	local uvChannel = 2
	if(classof (unwrapMod) == Unwrap_UVW and unwrapMod.getMapChannel() == UVChannel) then
		unwrapMod.setMapChannel 2
		unwrapMod.selectOverlappedFaces()
		overlappingUVWFaces = unwrapMod.getSelectedFaces()
	else
		addModifier  geo (Unwrap_UVW())
	if overlappingUVWFaces.numberSet > 0 then
		return false
	else
		return true
10 REPLIES 10
Message 2 of 11
denisT.MaxDoctor
in reply to: LayTiger
Do you need to check just a fact of overlapping, or do you need to know which particular faces are overlapped?
Message 3 of 11
LayTiger
in reply to: denisT.MaxDoctor
I just need a fact of overlapping.
Message 4 of 11
denisT.MaxDoctor
so you can use the xView and UVW_Mapping_Clear modifier(s) to temporarily clear unwanted channels.
of course, you can use a temp UVW_Unwrap modifier but it's the much heavier solution.
Message 5 of 11
denisT.MaxDoctor
question #2: How big is your mesh? Large meshes can be critical for the xView
Message 6 of 11
LayTiger
xView and UVW_Mapping_Clear modifier(s) actually works, thank you very much.
	addModifier geo (UVW_Mapping_Clear())
	uvwClear = geo.modifiers["UVW_Mapping_Clear"]
	uvwClear.mapID = 1
	overlappingUVWFaces = #()
	OverlappedUVWFaces.Check currentTime geo &overlappingUVWFaces
	overlappingUVWFacesCount = overlappingUVWFaces.count
	deleteModifier geo uvwClear
	if(overlappingUVWFacesCount > 0) then
		return false
	return true
Message 7 of 11
LayTiger
It's a game asset, usually have no more than 10000 faces, maybe it's ok to use xView?
Message 8 of 11
denisT.MaxDoctor
Give it a try, who knows... 😁
I believe it should work with 100K, but not in real time of course.
Message 9 of 11
denisT.MaxDoctor
	uvwClear.mapID = 1
		return false
	return true
fn CheckOverlappedUVWInSecondUV geo excludeCh: =
	uvwClear = undefined
	if excludeCh != unsupplied do
		uvwClear = UVW_Mapping_Clear mapid:excludeCh
		addModifier geo uvwClear
	if uvwClear != undefined do deleteModifier geo uvwClear
	overlappingUVWFaces.count != 0
Message 10 of 11
LayTiger
wow, thank you for the optimized version!
Message 11 of 11
denisT.MaxDoctor
It's not an optimization really... yours is good too. Mine is more “mxs stylish”. 😉
