3ds Max Programming
Welcome to Autodesk’s 3ds Max Forums. Share your knowledge, ask questions, and explore popular 3ds Max SDK, Maxscript and Python topics.
glTFMaterial() undefined in macro
5 REPLIES 5
jmdvella
125 Views, 5 Replies
Previously this was working fine, now after the latest 3dsmax2024 updates I cannot assign a variable a glTFMaterial(). For example this will crash any script that uses the glTFMaterial():
macroScript GLBTest
    tooltip:""
    buttonText:""
    newMat = glTFMaterial()
    show newMat
How is this fixable? If I run the command when its not in a macro it works just fine.
5 REPLIES 5
jmdvella
in reply to: jmdvella
For those testing this, it works only the first time its evaluated. Put the button on the toolbar and restart 3dsmax and try again, it will fail
denisT.MaxDoctor
macroScript GLBTest
    tooltip:""
    buttonText:""
    show newMat
do
    if iskindof (gltf_mat = execute "glTFMaterial") Material do
		newmat = gltf_mat()
		show newmat
instead.
At the time the macro was loaded, the glTFMaterial class had not yet been defined.
jmdvella
in reply to: denisT.MaxDoctor
Thank you Denis!
Why does this work differently than every other current material?
Every other material type works like this including StandardMaterial (legacy), Physical Material, VrayMtl, CoronaMtl, etc
denisT.MaxDoctor
... different order of loading plugins. Some additional classes or third-party dlls may be loaded after all built-in ones.
jmdvella
Ah I see, very unforgiving lol...
Thank you!
Technology Administrators
