How to check overlapped UVW faces in specific map channel?
LayTiger
LayTiger
I tried xView "OverlappedUVWFaces.Check" first, but the function will return all overlapped uvw faces throughout all map channels.Then I found that "Select Overlapped Polygons" button in the UVW editor works well, so I tried to use the function to get overlapped uvw faces, but it seems not work in my code. Can somebody please help me?
fn CheckOverlappedUVWInSecondUV geo=
	local unwrapMod =  geo.modifiers["Unwrap_UVW"]
	local overlappingUVWFaces = #{}
	local uvChannel = 2
	if(classof (unwrapMod) == Unwrap_UVW and unwrapMod.getMapChannel() == UVChannel) then
		unwrapMod.setMapChannel 2
		unwrapMod.selectOverlappedFaces()
		overlappingUVWFaces = unwrapMod.getSelectedFaces()
	else
		addModifier  geo (Unwrap_UVW())
	if overlappingUVWFaces.numberSet > 0 then
		return false
	else
		return true
Accepted solutions (3)
Replies (10)
denisT.MaxDoctor
Do you need to check just a fact of overlapping, or do you need to know which particular faces are overlapped?
LayTiger
I just need a fact of overlapping.
denisT.MaxDoctor
so you can use the xView and UVW_Mapping_Clear modifier(s) to temporarily clear unwanted channels.
of course, you can use a temp UVW_Unwrap modifier but it's the much heavier solution.
denisT.MaxDoctor
question #2: How big is your mesh? Large meshes can be critical for the xView
LayTiger
xView and UVW_Mapping_Clear modifier(s) actually works, thank you very much.
	addModifier geo (UVW_Mapping_Clear())
	uvwClear = geo.modifiers["UVW_Mapping_Clear"]
	uvwClear.mapID = 1
	overlappingUVWFaces = #()
	OverlappedUVWFaces.Check currentTime geo &overlappingUVWFaces
	overlappingUVWFacesCount = overlappingUVWFaces.count
	deleteModifier geo uvwClear
	if(overlappingUVWFacesCount > 0) then
		return false
	return true
LayTiger
It's a game asset, usually have no more than 10000 faces, maybe it's ok to use xView?
denisT.MaxDoctor
Give it a try, who knows... 😁
I believe it should work with 100K, but not in real time of course.
denisT.MaxDoctor
	uvwClear.mapID = 1
		return false
	return true
fn CheckOverlappedUVWInSecondUV geo excludeCh: =
	uvwClear = undefined
	if excludeCh != unsupplied do
		uvwClear = UVW_Mapping_Clear mapid:excludeCh
		addModifier geo uvwClear
	if uvwClear != undefined do deleteModifier geo uvwClear
	overlappingUVWFaces.count != 0
LayTiger
wow, thank you for the optimized version!
denisT.MaxDoctor
It's not an optimization really... yours is good too. Mine is more “mxs stylish”. 😉
