Notice: Upload of PDF documents is currently unavailable across the Community due to an ongoing issue.
Spline Stroke
Spline Stroke
MehdiZangenehBar
Message 1 of 12
Spline Stroke
MehdiZangenehBar
What is the correct way to create stroke along a path (spline)?
My goal is to create a modifer using scripted plugin that will accept a spline and ouput a (2d) geometry or shape. something like this:
Replies (11)
Message 2 of 12
klvnk
what's wrong with the sweep modifier ?
Message 3 of 12
istan
how about spline thickness?
Message 4 of 12
MehdiZangenehBar
nothing, I just need to create from scratch to have full controll to add some more features, for example:
And so much more, So I need to create my own.
Message 5 of 12
MehdiZangenehBar
I need more than that. I just mentioned the start point.
Message 6 of 12
klvnk
the third one and the last are probably best done as different modifiers the last is best done as a "rail" modifier ie 2 splines to describe the outline shape . the 4th is just a delete mesh mod on top of the mod ( or 3 seperate meshes 😕 )
the trick with these kinds modifiers in the sdk is to use the polyline (the visual representation extracted from the bezier) as the basis and not the actual bezier. Unfortunately to my knowledge this is not available in mxs (though you can approximate it). You then compute all the frenets (search the sdk and theres multiple versions)  (array of xforms) a basis xform  (computes the tolocal xform) as you can have more than one spline. There some really tricky maths for keeping a constant cross section (not included in the sdk versions 😐 )  and some post processing funkiness to make sure everything connects nicely in the case of a closed spline.
Message 7 of 12
denisT.MaxDoctor
The 2D version is very easy to implement in MXS. I would do it as SimpleObj - a spline is deforming a plane..... For a 2D spline, it is very easy to get a matrix in any curve parameter. This matrix should be used to transform the vertices of the "plane". A curve controls or Bézier controllers can give the scale and offset.
I remember a very similar plugin I showed in CGTalk.
I also remember a very good example of a plugin from Swordslayer on a similar theme.
Message 8 of 12
denisT.MaxDoctor
Another simple solution is to use the "Rendered" spline with the "Rectangular" option. Remove all unnecessary and tessellate what you need.
Message 9 of 12
MehdiZangenehBar
Yea, 2d version using simpleobj does the job I think, would please repost the sample here, sadly we don't have access to CGTalk archive anymore.
Message 10 of 12
MehdiZangenehBar
Yea, I need them all in one modifier, and yes I need a new shape or mesh at top of the spline.
Message 11 of 12
MehdiZangenehBar
C# version using Autodesk.max.dll also works for me.
Message 12 of 12
istan
I'd use simple splines and would create the mesh on my own - but C++ has "better" access to splines, imho.
