Shader effects
Shader effects
MehdiZangenehBar
Message 1 of 8
Shader effects
MehdiZangenehBar
Whats is the correct way to program a custom shader (shader effects) using MSX - C# ?
Something like Photoshop layer effects, For example Bevel, Innier Glow, Gradient, Stroke, etc?
Replies (7)
Message 2 of 8
MehdiZangenehBar
any idea?
Message 3 of 8
denisT.MaxDoctor
looks like a classic Bump... why do you need a custom shader?
Message 4 of 8
MehdiZangenehBar
Bevel is just an example Denis, I'm actually looking for a pipeline to create some 2D like maps. (Maybe I should call it 2D Textures, not shader...)
Something like OSL map (or shader), the problem with OSL map is that dosn't work with older Max.
I'm in R&D phase, So any reference, example or advice helps me a lot.
Message 5 of 8
denisT.MaxDoctor
With maxscript you can extend any TextureMap with a scripted plugin. There is an example in the help: "How to ... Create a Dalmatian TextureMap plugin".
Of course, this is a very limited solution, but in your example, it could be a Bump extension.
There are many examples in the c++ SDK (search Tex3D), but I don't know how possible it is to make such plugins via C#.
Message 6 of 8
denisT.MaxDoctor
In any case, I don't really understand the reason for customizing these things. It seems like you need something original to use with MAX's built-in renderer. Max has one of the most powerful built-in renderers and material sets. I don't believe there is anything that can't be created by just using what is already there.
Message 7 of 8
MehdiZangenehBar
Helps me a lot, thanks!
Message 8 of 8
MehdiZangenehBar
Indeed, But my goal is to convert 3dsMax to the software like Moho, ToonBoon and Spine
