WPF interface with TextBox...
kotorotomoto
kotorotomoto
I made a WPF interface that has a TextBox,
compiled it as a dll and displayed the window via maxscript.
Everything works fine, except for the TextBox, when i try to enter text, 3dsmax intercepts the input if the key used as a 3dsmax hotkey is pressed and it becomes impossible to enter text. I haven't found a solution, although I'm sure it's very simple.
MehdiZangenehBar
You should enable/disable acclerators on get/lost keyboard focus events of the textbox.
kotorotomoto
Yes, thanks! I had such an idea, but the solution seemed insufficiently elegant. But it works
