Help weight transfer script
davinwest72
Message 1 of 25
davinwest72
Edit. Solved.
Replies (24)
Message 2 of 25
denisT.MaxDoctor
@davinwest72 wrote:
Version gmax, which is exactly like 3dsmax4.2 ...
Are you a time traveler? An ancient artifact hunter? 😲
Discreet 3dsmax 4
Magma2000Windows 98, Windows ME, Windows 2000[6]
or maybe 3D Studio? 😂
Well... Do you want to make it good or easy? Good skin wrapping is a pretty complicated algorithm. What kind of meshes do you want to wrap?
Message 3 of 25
davinwest72
Edit. Solved.
Message 4 of 25
denisT.MaxDoctor
Is there no way to convert the data to a more recent version of MAX and, using something like OBJ, import it back in after skin wrapping?
Message 5 of 25
denisT.MaxDoctor
I'm also concerned about the MAXScript version... at the beginning of the 2000s it was pretty far from up to date, skinning support was very limited, and I'm not sure if skinops have been introduced yet.
Message 6 of 25
denisT.MaxDoctor
Skin wrapping based on the distance between vertices is very coarse. A much better result is given by a "face-based" algorithm. Both requires a lot of time and memory for large meshes, and something like a Kd-tree search engine is needed to speed it up... This is quite a heavy task for older versions assuming MAXScript implementation.
Message 7 of 25
davinwest72
Edit. Solved.
Message 8 of 25
denisT.MaxDoctor
I've been writing scripts for MAX for 25 years now... I'm not saying that what you're trying to do is completely impossible, but I see good reasons to look for alternative solutions.
Message 9 of 25
davinwest72
Edit. Solved.
Message 10 of 25
denisT.MaxDoctor
local boneIndices = for k = 1 to k - 1 where boneWeights[k] > 0 collect k
this is wrong for sure...
What is the typical number of vertices in the source and target meshes?
Message 11 of 25
davinwest72
Edit. Solved.
Message 12 of 25
denisT.MaxDoctor
@davinwest72 wrote:
I will reconfigure the line. The source mesh typically has about 400 verts. Target mesh will match or sometimes double that amount.
These are small meshes. You can do it the way you do it. There's no need for any clever "acceleration".
Message 13 of 25
davinwest72
Edit. Solved.
Message 14 of 25
denisT.MaxDoctor
I understand that you're interested in learning how to write scripts. Unfortunately, I don't have the time to explain everything in detail, but I can show you two basic functions that I used in one of my tools. If you take the time to understand them, you'll be able to advance your learning on your own.
It's worth mentioning that your current code isn't too far off from working properly.
So, are you ready to learn these functions?
Message 15 of 25
davinwest72
Edit. Solved.
Message 16 of 25
denisT.MaxDoctor
fn copySkinData node =
	sk = node.modifiers[skin]
	if iskindof sk Skin do
		max modify mode
		modpanel.setcurrentobject sk
		num = skinops.getnumberbones sk
		bones = for k=1 to num collect
			skinops.getbonename sk k 0
		weights = for k=1 to skinops.getnumbervertices sk collect
			num = skinops.getvertexweightcount sk k
			_bones = #()
			_names = #()
			_weights = #()
			for i=1 to num do
				id = skinops.getvertexweightboneid sk k i
				name = skinops.getbonename sk id 0
				weight = skinops.getvertexweight sk k i
				append _bones id
				append _names name
				append _weights weight
			#(k, _bones, _names, _weights)
		#(bones, weights)
fn pasteSkinData node data =
		max modify mode
		bones = data[1]
		num = bones.count
		for k=1 to num do
			if isvalidnode (bone = getnodebyname bones[k]) do
				skinops.addbone sk bone 1
		skinOps.Invalidate sk 1
		weights = data[2]
		num = weights.count
		for k=1 to num do
			_d = weights[k]
			_bones = for b in _d[3] collect (finditem bones b)
			skinops.replacevertexweights sk k _bones _d[4]
		#(skinops.getnumberbones sk, skinops.getnumbervertices sk)
If you create a map for the source and target vertices, these two functions will suffice for the skin transfer.
Message 17 of 25
davinwest72
Edit. Solved.
Message 18 of 25
denisT.MaxDoctor
fn mapNearestVerts source target =
	fn findNearest p verts =
		dist = distance p verts[1]
		n = 1
		for k=2 to verts.count where (d = distance p verts[k]) < dist do
			dist = d
			n = k
		n
	source_mesh = snapshotasmesh source
	target_mesh = snapshotasmesh target
	source_map = #()
	numv = source_map.count = source_mesh.numverts
	target_verts = for v=1 to target_mesh.numverts collect (getvert target_mesh v)
	for v=1 to numv do source_map[v] = findNearest (getvert source_mesh v) target_verts
	source_map
delete objects
s = geoSphere name:#source radius:25 segs:12 wirecolor:green
t = sphere name:#target radius:25 segs:32 wirecolor:orange
source_map =
	format "source:% target:%\n" (s.mesh.numverts) (t.mesh.numverts)
	t0 = timestamp()
	h0 = heapfree
	mm = mapNearestVerts s t
	format "\ttime:% heap:% count:%\n" (timestamp() - t0) (h0 - heapfree) source_map.count
	mm
Message 19 of 25
denisT.MaxDoctor
This example shows that we are good with source and target meshes of size ~1.5K and ~0.5K vertices.
You can play around with the number of segments to see how it affects performance
Message 20 of 25
denisT.MaxDoctor
If we copy from high-res to low-res, no problem here.... but mostly we need to copy from low-res to high-res. In this case, there is a problem because we can't do it well without averaging several near vertices.
