"Pick from object" hotkey script not working anymore (2024)
Hi! I use this script in 2023 to simulate the "pick material from object" button in SME, but since they've changed SME quite a lot, it's not working anymore and i have no idea how the person managed to make the "windows.Message" work in the first place.
	if MatEditor.mode == #basic then
		MatEditor.open() -- force basic medit in to focus, otherwise it won't work
		actionMan.executeAction 2 "1101"
	else
		if not SME.IsOpen() do SME.Open()
		fn GetSMEWindowHandle =
			max_hwnd = windows.getMAXHWND()
			for m in windows.getChildrenHWND 0 where m[4] == "NodeJoeMainWindow" and m[6] == max_hwnd do exit with m[1]
		local sme_hwnd = GetSMEWindowHandle()
		windows.sendMessage sme_hwnd 0x111 41005 0
The error i get now in 2024 is
"Type error: windows.sendMessage requires Rollout, RolloutFloater or Integer value, got: OK"
From what i've learned, the "NodeJoeMainWindow" is no more. Now it's "Qt5151QWindowIcon" instead, using a simple Window Spy.
Can anybody help? I just need a script that opens SME and pushes the (before) "Pick Material from Object" or (now) "Pick from Object".
Thanks!
I tried the 'right' way, but ended up doing the 'wrong'/ugly way, but it works, nevertheless.
AHK script
#Persistent
#SingleInstance, Force
#IfWinActive, Autodesk 3ds Max
; Block mouse (and keyboard) input
BlockInput, Default
; Sequence to simulate
Send, {Alt Down}
;Sleep, 10
Send, {Alt Up}
Sleep, 10
Send, {Right}
Sleep, 10
Send, {Down}
Sleep, 10
Send, {Enter 2}
#IfWinActive  ; End the specific window context
; Unblock mouse (and keyboard) input
BlockInput, Off
; Make ESC close the script
Esc::ExitApp
return
 and maxscript
macroScript PickMaterialSME24
Category:"PickMaterialSME24"
toolTip:"PickMaterialSME24"
buttontext:"PickMaterialSME24"
 SME.close()
 SME.Open()
 ahkScriptPath = "E:\\script.ahk" --path to script
 shellLaunch "autohotkey.exe" ahkScriptPath
I hope it helps!
