Open the file more than one hundred times, resulting in a crash
mx_zwh
Message 1 of 22
mx_zwh
-------------------maxscript -----------------------------
for i = 1 to 200 do(
loadmaxfile XXX Quiet:true
filein YYY
resetMaxFile #noprompt
It will crash at the 100th time
Replies (21)
Message 2 of 22
denisT.MaxDoctor
I see only one reason - some memory issue...
add this code to check the memory information to see how things go:
	r = sysinfo.getSystemMemoryInfo()
	for i = 2 to 7 do r[i] = (r[i] / 1024) / 1024.0
	format "MEMORY IN USE\t (\%)\n"
	format "\t\tused:\t%\n" 		(int r[1])
	format "PHYSICAL MEMORY\t (MB)\n"
	format "\t\ttotal:\t%\n" 		r[2]
	format "\t\tfree:\t%\n" 		r[3]
	format "\t\tused:\t%\n" 		(r[2]-r[3])
	format "PAGING FILE SIZE (MB)\n"
	format "\t\ttotal:\t%\n"		r[4]
	format "\t\tfree:\t%\n" 		r[5]
	format "\t\tused:\t%\n" 		(r[4]-r[5])
	format "VIRTUAL MEMORY\t (MB)\n"
	format "\t\ttotal:\t%\n" 		r[6]
	format "\t\tfree:\t%\n" 		r[7]
	format "\t\tused:\t%\n" 		(r[6]-r[7])
	ok
if there is a memory leak, it is in "filein"
Message 3 of 22
istan
you could also try a gc() in the loop - sometimes it helps.
Message 4 of 22
denisT.MaxDoctor
it makes a RESET max file according to the sample code above ... which is automatic garbage collection.
Message 5 of 22
mx_zwh
I tried using gc(), but the situation didn't get better. It was very painful
Message 6 of 22
trykle
Years of batch processing experience tells me, There is only one way:
open 3dsmax.exe, open max file, filein script, kill 3dsmax.exe
Message 7 of 22
denisT.MaxDoctor
you have to understand that what you're doing in filein is causing the crash... it's hard to tell what it is specifically without seeing the code. So the only solution seems possible is to fix the code you are using in filein.
Message 8 of 22
mx_zwh
This is too slow, but there seems to be no good way
Message 9 of 22
mx_zwh
filein file sample like
xxx.name = “xxxx”
max file save
Message 10 of 22
denisT.MaxDoctor
have you tried just only opening files? ... in sequence
fn batchLoadMaxFiles dir: =
	if dir == unsupplied do dir = getSavePath()
	if doesfileexist dir do
		files = getFiles (pathConfig.appendPath dir "*.max")
		if (count = files.count) do with quiet on
			cancel = off
			for k=1 to count while not cancel do
				if keyboard.escPressed then
					cancel = on
					format "\nBatch was canceled!\n"
				else
					file = files[k]
					format "%(%) ...\n" (formattedprint k format:"03d") (formattedprint count format:"03d")
					loadMaxFile file quiet:on allowPrompts:off
					format "\t>> %\n" file
					resetMaxFile #noPrompt
		count
/* RUN IT!
batchLoadMaxFiles()
Message 11 of 22
mx_zwh
I tried, but it still crashed
Message 12 of 22
mx_zwh
3dsmax2022
Message 13 of 22
denisT.MaxDoctor
what are these files? What is the main content : animation, geometry, materials?
Message 14 of 22
mx_zwh
animation file
Message 15 of 22
Serejah
did you try to load files in reverse order to ensure that it is indeed a script issue and not the corrupt scene file that leads to crash?
Message 16 of 22
denisT.MaxDoctor
@mx_zwh wrote:
animation file
Biped? Layers, Mixer?
How much memory do you initially allocate?
Message 17 of 22
mx_zwh
default:100
Message 18 of 22
denisT.MaxDoctor
Find one file that crashes the system due to 50–100 loads, and post it here. I will try to find a time to look at it.
I don't see any other way to figure out what's going on.
Message 19 of 22
mx_zwh
It's not a file problem. It's a problem with 3dsmax software. I changed different files. It's all like this,lol
Message 20 of 22
denisT.MaxDoctor
What if I tell you that some of my batches are 400–800 files each and they work stably?
However, it is up to you... You can blame the software if it helps you in any way.
