How to pass objects from the scene/viewport as parameters? C++
martim.grosner
Message 1 of 9
martim.grosner
I want to pass an object from the viewport as a parameter in a C++ function. It could be something like the classic teapot. I pass in the teapot and in my function I can access it's transform, rotation, scale and whatnot.
Replies (8)
Message 2 of 9
denisT.MaxDoctor
what do you mean by "passing" from the viewport? What does the process of "passing" look like according to your vision?
Message 3 of 9
istan
From my side I have two questions:
a) What do you mean with an "object"? A Node?
a) To which C++ function you want to pass such an "object"? To a MXS function? If we talk about nodes, there exist also node-handles, which can be shared between MXS and C++.
Message 4 of 9
martim.grosner
I mean passing an object as a parameter.
Example, you have Class A, and you have Function F. F looks something like this: F(A obj, int i){//body}
Now the class A in this example would probably be INode and 'obj' would be the object from the viewport.
While working on this I couldn't pass an 'obj' of class INode, but I could pass a pointer 'obj' that points to an INode.
Message 5 of 9
martim.grosner
3ds Max has many classes, and according to the documentation, an object(scene element) and a node are virtually the same here.
There's the Object class and there are scene elements/objects which are instances of classes that inherit from Object.
Answer to a), I mean the scene element/object, but acording to the link it is also the node.
Answer to b) I want to pass in a function like the one given as an example in my reply above. It is supposed to be an exposed function in the end. But would this affect anything?
Message 6 of 9
klvnk
the general procedure is...
your are going be passed (how ever that's done) a Node (class INode)
the node is going to  reference an object (the actual box, spline, editable mesh, poly etc), you look at the class of that object and decide if it's what you want
usually something like....
void myfunc(INode* node)
    if(!node) return;
    Object* obj = node->GetObjectRef();
    if(obj && obj.ClassID() == MY_CLASS_ID)
should be plenty of examples in the sdk, though things get a bit more complicated when modifiers an being used on the incoming node.
also worth noting that if you are storing this node in a parameter block the validation of the type is handled by the parameter block code using a PBValidator object (maxsdk\samples\controllers\Path_cnstrnt.cpp is a good example of this)
ChannelInfo project in samples is a good place to start on how to handle scene nodes
Message 7 of 9
martim.grosner
For a starting point I just want to access it's transform. I don't need to be defensive and make sure the passed object is the exact one I'm looking for. The INode should let me do it right?
Message 8 of 9
klvnk
virtual Matrix3 INode::GetObjectTM ( TimeValue time, Interval * valid = NULL )
does for most things
Message 9 of 9
istan
MaxSDK uses old C/C++ coding style - most "objects" will not be passed by reference, but by pointers.
