Announcements
How to invalidate render items
sukoy27k
sukoy27k
Hi
Regarding the render items in nitrous
https://help.autodesk.com/view/3DSMAX/2020/ENU/?guid=__developer_3ds_max_sdk_features_viewports_and_...
Usually a system based on render items is made in this way
bool CustomPlugin::PrepareDisplay(
      const MaxSDK::Graphics::UpdateDisplayContext& displayContext)
      // cook some new render items
bool CustomPlugin::UpdatePerNodeItems(
      const UpdateDisplayContext& updateDisplayContext,
      UpdateNodeContext& nodeContext,
      IRenderItemContainer& targetRenderItemContainer)
      // remove the existing render items
      targetRenderItemContainer.ClearAllRenderItems();
      // add the new render items
      for( auto& item: myRenderItems )
           CustomRenderItemHandle newHandle;
           newHandle.Initialize();
           newHandle.SetVisibilityGroup(RenderItemVisible_Gizmo);
           newHandle.SetCustomImplementation(mpSampleItem.GetPointer());
           targetRenderItemContainer.AddRenderItem(newHandle);
      return true;
The question is: how to invalidate the render items and triger the system to invoke again PrepareDisplay?
Actually now PrepareDisaply is only called when the frame changes.
sukoy27k
No one knows?
klvnk
sorry miss understood the question
sukoy27k
Seems to work
ptrMaxObject->NotifyDependents ( FOREVER, PART_DISPLAY, REFMSG_CHANGE );
GetCOREInterface ()->ForceCompleteRedraw ();
AtomLMW
This is what exactly I am looking for,  the solution of yours will work, however is this the reasonable way? The sdk document has said that "each object prepares the display data only once", so I am wondering when the UpdatePerNodeItems function will be invoke to update the object. From my debugging shows that this function will be invoked when the selected state of the object changed.
