max2027 crashes when using maxscript to display a WPF window
lgedZV4XV
Message 1 of 38
lgedZV4XV
In 3dsmax 2027, any WPF window created with maxscript will crash when show it, for example:
(dotnetObject "System.Windows.Window").Show()
Replies (37)
Message 21 of 38
denisT.MaxDoctor
Confirm it again: the only real option is to use ElementHost. I would estimate the chances of success at around 90%.
Technically, I don’t see any major difficulties. Windows Forms should work.
Message 22 of 38
spacefrog_
Just tested against the just released 3ds Max 2027.1 update and sadly IT'S not FIXED !!!
Josef Wienerroither
Software Developer & 3d Artist Hybrid
Message 23 of 38
Mr.Drm
    xamlstring = "
    <UserControl
        xmlns='http://schemas.microsoft.com/winfx/2006/xaml/presentation'
        xmlns:x='http://schemas.microsoft.com/winfx/2006/xaml'>
        <Grid Margin='10'>
			<TextBlock Text='Hello from WPF'/>
        </Grid>
    </UserControl>
    form = dotnetobject "system.windows.forms.form"
	form.text = "WPF in ElementHost"
    elementhost = dotnetobject "system.windows.forms.integration.elementhost"
    elementhost.child = (dotnetclass "system.windows.markup.xamlreader").parse xamlstring
    form.controls.add elementhost
    form.show()
I ran this simple script and 3ds Max 2027 crashed just as it did without using ElementHost!
Guys, please fix this issue as soon as possible – my working scripts are now useless!
Message 24 of 38
denisT.MaxDoctor
Nice snippet 👍
try this one:
    xamlstring = "
    <UserControl
        <Grid Margin='10'>
        </Grid>
    </UserControl>
    form = dotnetobject "MaxCustomControls.Maxform"
    form.Show()
Message 25 of 38
MartinBeh
@denisT.MaxDoctor wrote:
Nice snippet 👍
try this one
At least for me, this also does not work. Same thing: freeze of UI, no error message, crash to desktop.
Martin B   EESignature
→ please 'Like' posts that are helpful; if a post answers your question please click the "Accept Solution" button.
Message 26 of 38
denisT.MaxDoctor
Do you like using XAML as your source for WPF? That’s perfectly fine; I just want to narrow the scope a bit...
Message 27 of 38
denisT.MaxDoctor
I roughly understand how the breakage happens, what exactly Max breaks, and how it happens. I want to start the process so that by the time this breakage occurs, all internal structures are already properly initialized.
Message 28 of 38
denisT.MaxDoctor
Could you please tell me exactly which step causes the freeze and crash?
Message 29 of 38
denisT.MaxDoctor
After crashing the recent snippet, the chances of final success drop dramatically 😄 I guess the problem leaks into the WPF dispatcher afterward.
But even that is not fatal yet… what really matters is that the problem does not sink to the rendering level. If it does, then we’ll probably just have to throw our hands up.
Message 30 of 38
MartinBeh
Well... the line that crashes is
form.Show()
Not sure what else I can tell you?
Message 31 of 38
Mr.Drm
Yes, all my scripts have pure XAML UI.
Message 32 of 38
Mr.Drm
Thanks, but it doesn't work 😞
Message 33 of 38
Mr.Drm
This is the worst news I've heard in a long time... I hate maxscript UI controls, and rewriting all my tools to use it would be suicide for me...
Message 34 of 38
denisT.MaxDoctor
I don’t like rollout UI controls either, but for over 25 years they’ve somehow remained the only “correct” option... meanwhile, all my tools from the early 2000s are still alive and working perfectly fine in all versions.
Message 35 of 38
denisT.MaxDoctor
form.Show()
one more test (please tell the moment of the crash):
	xamlstring = @"
	<UserControl
		<Grid Margin='10'>
		</Grid>
	</UserControl>
	form.Text = "WPF in ElementHost"
	elementhost = dotnetobject "System.Windows.Forms.Integration.ElementHost"
	form.controls.Add elementhost
	form.Showmodeless()
	---form.Close()
	elementhost.Child = (dotnetclass "System.Windows.Markup.XamlReader").parse xamlstring
	try(form.close()) catch()
	form.Text = "WPF in Form"
	form.StartPosition = form.StartPosition.Manual
	form.Location = dotnetobject "System.Drawing.Point" 200 100
	form.Size = dotnetobject "System.Drawing.Size" 400 200
	form.BackColor = form.BackColor.Red
	panel1 = dotnetobject "Panel"
	panel1.Dock = panel1.Dock.Fill
	panel1.BackColor = panel1.BackColor.Red
	panel2 = dotnetobject "Panel"
	panel2.Height = 40
	panel2.Dock = panel2.Dock.Top
	panel2.BackColor = panel2.BackColor.Yellow
	ehost = dotnetobject "Integration.ElementHost"
	ehost.Dock = ehost.Dock.Top
	ehost.Width = 100
	ehost.Height = 20
	wpb = dotnetobject "System.Windows.Controls.ProgressBar"
	b = dotnetobject "System.Windows.Media.SolidColorBrush" ((dotnetclass "System.Windows.Media.Color").FromRGB 255 0 0)
	wpb.Foreground = b
	wpb.Width = 100
	wpb.Height = 20
	wpb.Value = 50
	ehost.Child = wpb
	panel2.Controls.Add ehost
	form.Controls.Add panel2
	form.showmodeless()
... and this one:
Message 36 of 38
Mr.Drm
first test:
elementhost.Child = (dotnetclass "System.Windows.Markup.XamlReader").parse xamlstring //<--- crash on this line
second test:
form.showmodeless() //<--- crash on this line
Message 37 of 38
Mr.Drm
Well, not all interfaces can be built with MaxScript controls. For example, I have an XALM UI, and the business logic is in MaxScript. Everything worked fine until 3dsmax2027.
Message 38 of 38
denisT.MaxDoctor
I don’t mean any unique UI cases. In this situation, anything that works is good enough — WPF, .NET, Qt, whatever.
But if you start overcomplicating things just because you want to make the interface fancy, be ready for it to become a problem sooner or later.
