max2027 crashes when using maxscript to display a WPF window
lgedZV4XV
Message 1 of 58
lgedZV4XV
In 3dsmax 2027, any WPF window created with maxscript will crash when show it, for example:
(dotnetObject "System.Windows.Window").Show()
Replies (57)
Message 2 of 58
spacefrog_
Can confirm the crash ( Works in 2026 )
just for completeness, also happens if you do something like
w= dotnetObject "System.Windows.Window"
w.Show()
w is a valid window object and  one can set properties etc ...
Josef Wienerroither
Software Developer & 3d Artist Hybrid
Message 3 of 58
lgedZV4XV
It works fine in max2010-2026, only crashs in max2027..
Message 4 of 58
A娘
only dynamical wpf window throw error , when write as xaml in a dll , run normal
Message 5 of 58
lgedZV4XV
If you show the window in maxscript, the wpf window written in the dll will also crash.
w = dotnetObject "YourDll.YourWindow"
w.Show() --Crash!
w = (dotnetClass "YourDll.YourWindow").GetWindow()
w.Show() --Crash!
Only WPF dlls written in pure c# that don't interact with maxscript don't crash, but there is a lot of interaction in many projects. is Autodesk aware of this problem?
Message 6 of 58
MartinBeh
FYI, the bug has been reported to the team.
Martin B   EESignature
→ please 'Like' posts that are helpful; if a post answers your question please click the "Accept Solution" button.
Message 7 of 58
ads_decatae
Thanks again for that @MartinBeh !
Elena de Catalina
Sr. QA Analyst
Entertainment Creation Products, ECP
Message 8 of 58
lgedZV4XV
Is there any way to fix this bug?
Message 9 of 58
maxencoding
Community Visitor
Community Visitor
I've been following this issue closely, refreshing the page almost daily for new replies, hoping to find out when it will be fixed or if there are any temporary solutions.  @MartinBeh
Message 10 of 58
MartinBeh
All I can say is that is has been logged into the official bug report database - not idea when/how/for which version of 3ds Max this will be fixed, sorry.
Maybe one of the more dotNet savvy folks around here knows a workaround until there is an update that fixes this for good?
Message 11 of 58
lgedZV4XV
Thanks all the same!
Message 12 of 58
denisT.MaxDoctor
If you are reporting a crash, please provide a bit more detail about how it happens.
Does it crash immediately on Show(), after the window appears, or when the window is closed?
Also, are there any error messages or outputs shown anywhere:
- MAXScript Listener
- Autodesk crash dialog (CER)
- any other console or log output
Right now most reports only say “it crashes”, but without the actual error output it is difficult to understand whether this is a WPF issue, a .NET hosting issue, or something else.
Message 13 of 58
maxencoding
Community Visitor
Community Visitor
As mentioned above, simply open 3ds Max 2027 and execute the code `(dotnetObject "System.Windows.Window").Show()` in the script editor. 3ds Max will freeze completely, with no response or output. This is the simplest method I can verify. In my personal WPF project, the UI displays correctly if only `show` is called, but if `set` or `get` is used to interact with the UI, the same problem occurs: 3ds Max freezes and displays no output.
Message 14 of 58
spacefrog_
This is what i get:
Josef Wienerroither
Message 15 of 58
denisT.MaxDoctor
This error message is much better than nothing.
Message 16 of 58
denisT.MaxDoctor
I don't have version 2027, and I don't need to install it yet...
So I recommend trying something like this first:
w = dotnetObject "System.Windows.Window"
w.Title = "WPF Test"
w.Width = 300
w.Height = 200
hlp = dotnetObject "System.Windows.Interop.WindowInteropHelper" w
hlp.Owner = windows.getMAXHWND()
w.Show()
We need to figure out where the problem is.
Message 17 of 58
MartinBeh
This causes 3ds Max to freeze up for 20 seconds and then fast-exit to desktop, no error message.
This is what the Listener shows while doing so:
Message 18 of 58
denisT.MaxDoctor
how is about ShowDialog() instead?
there is another way to try:
w.Width = 300
w.Height = 200
m = (w.GetType()).GetMethod "Show"
m.Invoke w #()
In theory, all should work the same... but it's definitely a MAX's bug, and there might stay some ways that aren't broken.
Message 19 of 58
MartinBeh
Again, the UI freezes up, fast-exit to desktop.
Here is the Listener output:
Message 20 of 58
denisT.MaxDoctor
What would I recommend if I urgently needed this in Max 2027 and couldn’t wait for Autodesk to fix the bug?
I would do the following: first, check whether Windows Forms still work. If they do, then I would wrap the WPF window inside a Windows Forms window and launch it through the Form.
