How to clone object using python
mateusz.zelent
Message 1 of 9
mateusz.zelent
could you help how to duplicate object using python script ind 3Dmax 2018?
MZ
Replies (8)
Message 2 of 9
morten_bohne
If you just want to copy the selected node, you could do it like this:
from pymxs import runtime as rt
# get the selected node
sel = rt.selection[0]
# copy selected node
rt.copy(sel)
Message 3 of 9
mateusz.zelent
thank you for your response.
I have found second way:
MaxPlus.Core.EvalMAXScript("myType = #copy")
rt.maxOps.cloneNodes(rt.mySphere2,  cloneType=rt.myType)
My goal is to create a vector field (space of 3d of arrows):
Znalezione obrazy dla zapytania vector fields
I do not know how to draw an arrow using python code, so I would like to clone an already created one. Then I plan to give them rotation and location later. What do you think is the best way to achieve this?
Message 4 of 9
morten_bohne
that works too 🙂
If you want to get rid of the EvalMaxScript part, you could do it like this:
rt.maxOps.cloneNodes(sel, cloneType = rt.name("copy"))
and to create a grid of objects:
count = 3
offset = 50
for x in range(count):
	for y in range(count):
		for z in range(count):
			node = rt.teapot()
			node.pos = rt.point3(x*offset, y*offset, z*offset)
Message 5 of 9
mateusz.zelent
Perfect!
Thank you for help, now I know also how to create an arrow, but do you know how to connect these two objects into one node?
node=pymxs.runtime.cone()
node.radius1=1.8
node.height=3.5
node.pos=rt.point3(0,0,5)
node=pymxs.runtime.cylinder()
node.radius=0.9
node.height=5
node.pos=rt.point3(0,0,0)
Message 6 of 9
morten_bohne
import pymxs
cone=pymxs.runtime.cone()
cone.radius1=1.8
cone.height=3.5
cone.pos=rt.point3(0,0,5)
cylinder=pymxs.runtime.cylinder()
cylinder.radius=0.9
cylinder.height=5
cylinder.pos=pymxs.runtime.point3(0,0,0)
pymxs.runtime.convertToMesh(cone)
pymxs.runtime.convertToMesh(cylinder)
pymxs.runtime.attach(cone, cylinder)
arrow = cone
arrow.pivot = pymxs.runtime.point3(0,0,0)
Message 7 of 9
mateusz.zelent
Thanks to you, right now I am very close to finish this task!
I hope that will be a last question, do you know how to assign material to each node?
I would like to do smh like this:
1. Select node 1,
2. assign to the node Scanline -> Standard,
3. Set the color, and material properties.
Message 8 of 9
morten_bohne
tpot = rt.Teapot()
mat = rt.StandardMaterial()
tpot.material = mat
mat.Diffuse_Color = rt.color(255, 0, 0)
Message 9 of 9
mateusz.zelent
how to select standard material I know, but how to select a different one and then control its parameters?
Mateusz
