Announcements
How do I create an animation of a Material Modifier (in C++)
johnny.johanssonSZ55P
Message 1 of 10
I am new to the SDK and animations seem like a complex subject, so I am not even sure where to start looking.
I have created a Material Modifier:
Modifier *material_modifier = (Modifier*)i7->CreateInstance(OSM_CLASS_ID, Class_ID(MATERIALOSM_CLASS_ID, 0));
And I have successfully associated it with a number of nodes in the scene:
GetCOREInterface12()->AddModifier(*node, *material_modifier);
So far everything works, but I also need to animate the modifier so that at frame 0, the ID is 0 and at frame 1, the ID is 1 and so on. Probably very easy if you know enough, but I am pretty lost. There are no other animations in this scene if that makes a difference.
I would really appreciate it if anyoune could point me in the right direction!
Replies (9)
Message 2 of 10
istan
Where does your "ID" come from?
If you use standard paramblk values, the animation will be handled from Max without any extra code from your plugin (with a suitable controller).
Message 3 of 10
My "ID", do you mean MATERIALOSM_CLASS_ID? This is what I, by trial and error, figured out I need to use in order to create a Material modifier. It is quite possible that there is a better way to do that, but on the other hand, this part seems to be working.
To clarify, I am not developing any new functionality here. I am trying to automate certain steps that are already available and could be done manually in 3DS. The steps are:
1 - Create a Material modifier, which I have done and it is working.
2 - Associate it with certain nodes, which I have done and can verify in 3DS that it works.
3 - Animate the "Material ID" of the Material modifier, which is trivial to do, using "Auto Key" in 3DS, but I can not figure out how to do from code...
I hope this clarifies what my problem is. I would really appreciate any help I can get here!
Message 4 of 10
istan
ah.. ok..
Why don't you consider using MXS for this? You could call MXS from C++.
Otherwise, I would search the SetValue() id in the samples for this specific parameter. But since this ParamBlock has just one parameter, I would test with ParamBlk Id=0.
Message 5 of 10
MXS = Maxscript, right? Which might be a good idea, although, this problem is just a small part of huge Maxscript based process that I am rewriting as a plugin in C++, because once you get to a certain code size, Maxscript becomes totally unmaintainable. I could do limited parts as Maxscript though and call them from the plugin.
However, I seem to have stumbled upon a solution. One of the first things I tried was this:
IParamArray *P = material_modifier->GetParamBlock();
IParamBlock *PB = P->GetParamBlock();
for (int i = 0; i < num_materials; ++i) {
	// Hardcoded for 30 fps.
	constexpr int fps = 30;
	constexpr int ticks_per_frame = TIME_TICKSPERSEC / fps;
	PB->SetValue(0, i * ticks_per_frame, i + 1);
But it would not work, only the last of the values was set and there was no animation. However, I just found out that if i call AnimateOn() before the loop and AnimateOff() after, it works!
This seems more like hacking than programming to me, but as long as this is working, I am going to stick with it!
Thank you for your efforts though, I appreciate it!
Message 6 of 10
istan
yes, I abbreviate MaxScript by MXS since decades 😉
Instead of using AnimateOn() you could also directly add keys to the controller of the ParamBlk value..
Message 7 of 10
That sounds like a much neater solution, but I tried a bunch of stuff like that and the problem is that PB->GetController(0) returns NULL. I assume this is because the modifier isn't animated (PB->isAnimated() returns false).
So it is a Catch-22: I can't add keyframes to animate the modifier, because the modifier isn't animated...
Message 8 of 10
istan
Have you also tried assigning a new controller with pb->SetController() first?
Message 9 of 10
No, I have not tried exactly that. I did try to AssignController(NewDefaultFloatController(), 0) directly to the Modifier, but that would fail (return FALSE) and I abandoned that line of investigation.
But setting a new (default float) controller on the IParamBlock per your suggestion does allow me to create keyframes where I need them, but I am failing to set different values. All keyframes get the same value.
Looking at the header file comments for Control::SetValue, I note that:
Note: Developers who want to create keys for a keyframe controller by calling SetValue() directly can do so, but the animate button should be turned on using the following code:
SuspendAnimate()
AnimateOn()
Call SetValue() -- make sure commit=1
ResumeAnimate()
So I guess there really is no way to do this without messing with global state!
Message 10 of 10
istan
Did you ever see your keyframes in the e.g. curve editor?
btw, take a look at \maxsdk\howto\import_export\asciimp\import.cpp
