Get the current numeric PERCENT value from a "path constraint float script
truckexpert
truckexpert
How do I get the current numeric PERCENT value from a "path constraint float script?
Thanks.
Dave
SYSINFO
Dell Precision 7920 Tower
BaseBoard 060K5C
Intel Xeon Silver 4110 CPU @ 2.10GHz, 2095 Mhz, 8 Core(s), 16 Logical Processor(s)
NVIDIA Quadro P1000 - Adapter RAM (1,048,576) bytes
Physical Memory (RAM) 32.0 GB
Windows 10 Pro
3DS Max 2021
Peace,
Dave
System Information:
3DS Max 2023 and 2024
Microsoft Windows 11 Pro
Dell Precision 5820
Intel(R) Core(TM) i9-10920X CPU @ 3.50GHz, 3504 Mhz, 12 Core(s), 24 Logical Processor(s)
Display Adapter: NVIDIA RTX A4000
Installed Physical Memory (RAM) 64.0 GB
Total Physical Memory 63.7 GB
Available Physical Memory 45.6 GB
Total Virtual Memory 81.7 GB
Available Virtual Memory 56.5 GB
Page File Space 18.0 GB
denisT.MaxDoctor
what is "path constraint float script"?
I know "path constraint" and "float script" ... what are they together?
truckexpert
Thank you for your reply.
Assume a dummy named "Dummy1" is moving along a spline path named "Path1".
      I am controlling the percent progress of Dummy1 along the spline (length L) using a "float script" controller, so as to allow the user to specify the speed, so that %Dist = speed*time/L.   I simply want the script to print the current value of the percent progress (along with time and distance) to create a table in the listener window as the script runs, but I don't know it's name (it isn't %Dist) or how to refer to it.
Peace,
Dave
System Information:
Dell Precision 5820
denisT.MaxDoctor
delete objects
p = circle name:#path radius:30 wirecolor:green
t = teapot name:#source radius:5 wirecolor:orange
c = t.pos.controller = path_constraint path:p follow:on
s = c.percent.controller = float_script()
s.addconstant #velocity 0.5
s.addconstant #period 4.0
s.addconstant #debug false
ss  = ""
ss += "local value = sin (period * F) * velocity\n"
ss += "if debug do format \"frame:% secs:% period:% velocity:% == value:%\\n\" F S period velocity value\n"
ss += "value\n"
s.setexpression ss
	s.setconstant #debug on
	for t = 0 to 100f by 10 do at time t
		format "\t% >> percent:%\n" t c.percent
	s.setconstant #debug off
Use this as an example. Of course, the #debug option should be disabled in real time and should be used with data output (check, debug).
truckexpert
Thank you again!! I have learned a lot from the above script. You obviously have finessed the art of Maxscript programming!
Peace,
Dave
System Information:
Dell Precision 5820
