公告
Determine where 2 extruded lines intersect
kenc
3,527 次查看
36 条回复
1 条消息(共 37 条)
kenc
If I have 2 walls(lines) crossing over or one of them is just touching the other, how do I determine at what point they intersect.
TIA
Ken
0 个赞
已接受的解答 (1)
3,528 次查看
36 条回复
回复 (36)
2 条消息(共 37 条)
denisT.MaxDoctor
I'd love to help you, but you're on my blacklist. I don't appreciate it when someone claims “solutions” for themselves, even if they are their own. You have eight “solutions,” all marked by you. That's not how things should work.
0 个赞
3 条消息(共 37 条)
kenc
I'm sorry. I thought that is what I was supposed to do
0 个赞
4 条消息(共 37 条)
kenc
Who marks it as a solution?
0 个赞
5 条消息(共 37 条)
kenc
@denisT.MaxDoctor I just went through our previous threads and I do see what I did wrong.
In those I accepted solution. Also noticed 2 real old threads with marked accept solution by the moderator
0 个赞
6 条消息(共 37 条)
denisT.MaxDoctor
are we talking about Bezie splines or just a simple Linear?
are we talking about 2D intersections? meaning projection
0 个赞
7 条消息(共 37 条)
kenc
@denisT.MaxDoctor I am talking about 3D linear walls. The point when one wall touches or passes through another wall.
0 个赞
8 条消息(共 37 条)
MartinBeh
You don't mention what you want to do once you have the intersection, but 3ds Max has the "Section" shape which computes the intersection of a mesh with a plane - does that help?
Martin B   EESignature
→ please 'Like' posts that are helpful; if a post answers your question please click the "Accept Solution" button.
0 个赞
9 条消息(共 37 条)
kenc
@MartinBeh Where Line002 crosses Line001. I need to divide Line001 in two.
0 个赞
10 条消息(共 37 条)
MartinBeh
So you want to cut one plane along the line of intersection of that plane with another?
You could use a Slice modifier for this. If you want, you could remote-control the modifier's gizmo with the gizmoControl script of mine.
Or maybe the Procutter compound would be a way to do that?
0 个赞
11 条消息(共 37 条)
kenc
I better expand on what I need to do. I should have done this from the start.
I have a house full of walls. I have to check which wall intersects with what walls. I can do this with
intersects $Wall001 $Wall002.
When I find a wall that intersects another wall that wall needs to be split in two.
Here is an example
Wall005 and Wall006 intersect with Wall001. I need Wall005 to split Wall001 in two. As well as Wall006 to split it in two.
I am using MAX 2019
0 个赞
12 条消息(共 37 条)
denisT.MaxDoctor
Typically, in any architectural project, “wall line” refers to a horizontal line (floor plan), not a vertical line. In this case, we can talk about the intersection in 2D (floor), or in 3D, assuming there is another vector making the wall plane “UP”.
If you use a vertical line for the wall, you need another vector to define the wall plane... where to get it?
0 个赞
13 条消息(共 37 条)
kenc
@denisT.MaxDoctor I'm not following what you are getting at.
The walls are extruded lines and then collapsed to edit poly.
0 个赞
14 条消息(共 37 条)
denisT.MaxDoctor
Walls are usually extruded vertically. In your original pipeline, they are extruded horizontally. Maybe it makes sense to modify the pipeline first?
0 个赞
15 条消息(共 37 条)
kenc
@denisT.MaxDoctor  in both my screenshots above, the walls are extruded vertically
0 个赞
16 条消息(共 37 条)
denisT.MaxDoctor
According to this picture, the lines are vertical.
Well, uh. What do you need? Math, how do you calculate the intersecting point of two segments?
0 个赞
17 条消息(共 37 条)
denisT.MaxDoctor
已接受的解答
fn segs_cross_point p11 p12 p21 p22 =
	a = p12 - p11
	b = p22 - p21
	c = p21 - p11
	mag = cross a b
	len = (length mag) ^ 2
	p0 = p11 + a * (dot (cross c b) mag)/len
	p1 = p21 + b * (dot (cross c a) mag)/len
	(p0 + p1)/2
delete objects
--seed (timestamp())
p11 = point name:#p11 pos:(random -[100,100,0] [100,100,0]) cross:on wirecolor:green
p12 = point name:#p12 pos:(random -[100,100,0] [100,100,0]) cross:on wirecolor:green
p21 = point name:#p21 pos:(random -[100,100,0] [100,100,0]) cross:on wirecolor:yellow
p22 = point name:#p22 pos:(random -[100,100,0] [100,100,0]) cross:on wirecolor:yellow
v = segs_cross_point p11.pos p12.pos p21.pos p22.pos
cp = point name:#cross pos:v cross:on wirecolor:red
18 条消息(共 37 条)
kenc
@denisT.MaxDoctor and how to break the wall at the intersection.
Wow, high school math. I was not expecting that.
I thought there would have been a built-in function to determine the point of intersection. Like intersects $Wall001 $Wall002. It determines if they intersect but no function to determine the point of intersection.
0 个赞
19 条消息(共 37 条)
MartinBeh
What intersects really does is:
Returns true if the bounding boxes of the two specified nodes overlap, or false if they do not overlap
0 个赞
20 条消息(共 37 条)
kenc
@MartinBeh What I'm saying is if script can determine an intersection occurring, then why not determine the point of intersection.
0 个赞
