Announcements
Xml Object security exception
maeshima
maeshima
When using 3dsmax 2023 or later versions, why does a "security exception" occur when using a .NET object (Xml Object) in MaxScript?
Also, what is the workaround?
MartinBeh
You would need to post more details (code, error messages, screenshots) but right now, it sounds a bit like you are coming across a new security feature introduced to 3ds Max to prevent malicious code from running.
For diagnostics you could try to temporarily disable the Security Tools (I do NOT recommend to leave them disabled for longer!) and see whether that removes the issue?
Martin B   EESignature
→ please 'Like' posts that are helpful; if a post answers your question please click the "Accept Solution" button.
maeshima
We disabled "Block 3rd party .NET code" and the error disappeared!
Thank you.
maeshima
Thank you.
