z-depth element not rendering when anti-aliasing disabled
futengda
Message 1 of 1
futengda
This issue comes from the 3ds Max forum board, link. It should be a programming-related issue, so it has been moved here. The original description is:
I need to use the texture obtained from the z-depth renderElement for depth testing to perform some occlusion culling. For extreme cases, such as when the model is particularly small and occupies only a few pixels in the z-depth map, if anti-aliasing is enabled, its grayscale value will be "polluted," making it hard to make correct judgments. However, the problem is, when I try to turn off anti-aliasing, the z-depth simply does not render at all?
I'm using Max 2023.3.4
But actually, I found that even using the Render API to render the z-depth render element, this issue still exists.
render camera:MyCam outputsize:[512,512] channels:#(#zDepth) \
    renderElements:true renderElementBitmaps:&reb renderhiddenobjects:false vfb:off  \
    antiAliasing:false -- !!!NOTE: this will make the depthmap completely black
So, I believe this issue is common and unrelated to whether it's through the GUI or a script.
For now, based on the current situation, the only solution for me at the moment is to increase the resolution of the output size.
Replies (0)
