How to restore viewport size with maxscript command?
maxyweb
Message 1 of 17
maxyweb
I can hide-show Time Slider or hide-show Ribbon and this will restore the viewports, but this is bad option. Is there a command that restores viewports?
Thanks!
Replies (16)
Message 2 of 17
denisT.MaxDoctor
How did this happen? What did you do to shift (scale) it like that?
Message 3 of 17
MartinBeh
Probably related to https://forums.autodesk.com/t5/3ds-max-programming/how-to-create-floating-viewport-with-specific-siz...
Martin B   EESignature
→ please 'Like' posts that are helpful; if a post answers your question please click the "Accept Solution" button.
Message 4 of 17
denisT.MaxDoctor
This is the main panel as I see it... something needs to be done to screw it like that.
Message 5 of 17
maxyweb
Yes, I reduce the base viewport to the required size of 800x600, take a screenshot and it works fine, there is a problem that the viewport does not always return to the original size. The question was: is there a maxscript command that updates the size of viewports as does changing the UI configuration. For example, turning on or off the Time Slider restores the viewport size, but writing macros.run "Customize User Interface" "UI_TimeSlider_Toggle" into the script is a clumsy solution
Message 6 of 17
denisT.MaxDoctor
Yeah, I was expecting something like that...
- How do you fix a TV?
- What's wrong with it?
- The sound's gone.
- What do you mean, it's gone?
- I was watching TV, picking at my ear with a screwdriver, and the sound's gone...
Message 7 of 17
maxyweb
ok, let's chalk it up to translation difficulties
I suspect the joke is funny)
Message 8 of 17
denisT.MaxDoctor
I still don't understand why you try to scale the viewport to take a snapshot of a given size... take a DIB with the current or larger size and scale the image.
src=gw.getViewportDib()
trg = bitmap 800 600
copy src trg
display trg
Message 9 of 17
maxyweb
Because if the viewport does not have a 4x3 aspect ratio, and most often this is the case, then the screenshot turns out to be stretched vertically.
like in this example:
copy src trg
display trg
In order to get the correct screenshot, I first need to make the viewport aspect ratio 4x3 (800x600)
Message 10 of 17
denisT.MaxDoctor
so what? just do it:
	size = [800, 600]
	ratio = size.x / size.y
	if (1.0 * src.width / src.height) != ratio do
		if (src.width > src.height) then
			h = src.height
			w = int (h * ratio)
			bb = box2 ((src.width - w)/2) 0 w h
		else
			w = src.width
			h = int (w / ratio)
			bb = box2 0 ((src.height - h)/2) 0 w h
		tmp = bitmap w h
		pastebitmap src tmp bb [0,0]
		src=tmp
	trg = bitmap size.x size.y
	copy src trg
	display trg
Message 11 of 17
maxyweb
In this case, some of the information is cut off and it is not clear from which camera the screenshot was takenVoPqXMEhIz.png
Message 12 of 17
denisT.MaxDoctor
That's it! You're too picky! You're on your own from here...
Message 13 of 17
maxyweb
Yes, there is such a thing)
That's why I didn't ask a complex question, I asked a simple one.
I'm sure there is a simple solution to restore the viewport size, but I haven't found it, and since not everyone needs it, not everyone knows.
There was hope)
Message 14 of 17
denisT.MaxDoctor
I wrote dozens of tools similar to that in my practice...
your problem is that you went in the wrong direction from the beginning, but I couldn't convince you. So ... you're on your own now.
Message 15 of 17
maxyweb
I have been watching you for a long time, starting with CGtalk, and I admit that you are the most experienced expert on this topic, I especially appreciate your desire to share your knowledge. But no one can know absolutely everything. Perhaps I chose the wrong path, but it works, although not exactly as I would like. In any case, thank you for being there, respect! )
Message 16 of 17
denisT.MaxDoctor
at least how to update the view panel with a single command, I know for sure....
Message 17 of 17
maxyweb
Let it remain a secret, otherwise it will be boring )
