Center Islands to Main 0-1 UV Space
rartidiello
Message 1 of 11
rartidiello
I have a mesh with the UVs shifted. Thousands of Islands that after being packed, are shifted (adding/subtracting whole units) into different UV quadrants. I need a script that moves all islands to the main UV Space as it was packed originally. Island by island move them by whole units until they are in the 0-1 range (subtract the whole part of its position so it is U: 0,xxx V: 0,xxx).
Thanks.
Replies (10)
Message 2 of 11
denisT.MaxDoctor
Could you provide a picture of the desired result?
Message 3 of 11
rartidiello
yes sure,
Message 4 of 11
denisT.MaxDoctor
delete objects
--seed 0
/****************************** MAKE example mesh *************************/
mm = for k=1 to 100 collect (circle radius:(random 1 10) pos:(random -[100,100,0] [100,100,10]))
ms = mm[1]
converttomesh ms
for k=2 to 100 do meshop.attach ms mm[k]
meshop.applyuvwmap ms #planar
update ms
/***************************** PACK TV elements ***************************/
fn shiftMeshTvElement node tverts =
	u = 1e9
	v = 1e9
	pp = for tv in tverts collect
		p = gettvert node tv
		if p.x < u do u = p.x
		if p.y < v do v = p.y
		p
	shift = [u,v,0]
	k = 1
	for tv in tverts do
		settvert node tv (pp[k] - shift)
		k += 1
fn getAllMeshTvElements node =
	numf = node.numfaces
	numt = getnumtverts node
	local faces = #{1..numf}
	local verts = for v = 1 to numt collect #()
	local undone = #{1..numt}
	local elements = #()
	for k in faces do
		f = gettvface node k
		append verts[f[1]] k
		append verts[f[2]] k
		append verts[f[3]] k
	for i in faces do
		element = #(i)
		tverts = #()
		for j in element where faces[j] do
			faces[j] = false
			f = gettvface node j
			for k=1 to 3 do
				v = f[k]
				if undone[v] do
					join element verts[v]
					undone[v] = false
					append tverts v
		append elements (tverts as bitarray)
	elements
tvs = getAllMeshTvElements ms
for tv in tvs do shiftMeshTvElement ms tv
Message 5 of 11
rartidiello
I'm sorry but I don't think this script is moving the UV islands by whole units until they are in the main 0-1 UV space.
Message 6 of 11
denisT.MaxDoctor
The script finds all uv elements, calculates the bounding boxes of each element, and shifts the entire element by a given offset... that is 99% of the work. All you have to do is figure out how it works and add another 1% to make it work the way you want it to.
Message 7 of 11
rartidiello
I haven't make it work properly on my side😓. First the script is working for Editable Mesh and I needed it for Editable Poly(which I didn't specify) but even for Editable mesh it is not working as I need. For example in this sample Sphere.
it does this, and ignoring the peaks it is moving the islands to the origin (0.0.0) and not preserving their relative position on each quadrant.
this is the expected result.
Message 8 of 11
denisT.MaxDoctor
delete objects
--seed 0
/****************************** MAKE example poly *************************/
mm = for k=1 to 100 collect (circle radius:(random 0.1 1) pos:(random -[100,100,0] [100,100,10]))
ms = mm[1]
converttopoly ms
for k=2 to 100 do polyop.attach ms mm[k]
polyop.applyuvwmap ms #planar
update ms
select ms
fn shiftPolyMapElement node tverts channel:1 =
	fn roundFloor value tolerance:0.000001 =
		d = (value as float)/tolerance
		v = if (d - (v1 = floor d)) > ((v2 = ceil d) - d) then v2 else v1
		floor (v*tolerance)
	u = 1e9
	v = 1e9
		p = polyop.getmapvert node channel tv
		p
	shift = [roundFloor u, roundFloor v,0]
	k = 1
	for tv in tverts do
		polyop.setmapvert node channel tv (pp[k] - shift)
		k += 1
fn getAllPolyMapElements node channel:1 =
	numf = polyop.getnummapfaces node channel
	numt = polyop.getnummapverts node channel
	for k in faces do
		num = polyop.getfacedeg node k
		f = polyop.getmapface node channel k
		for i=1 to num do append verts[f[i]] k
	for i in faces do
		element = #(i)
		tverts = #()
			faces[j] = false
			num = polyop.getfacedeg node j
			f = polyop.getmapface node channel j
			for k=1 to num do
				v = f[k]
				if undone[v] do
					undone[v] = false
					append tverts v
	elements
tvs = getAllPolyMapElements $
for tv in tvs do shiftPolyMapElement $ tv
Message 9 of 11
rartidiello
This is working perfect, thanks!
Message 10 of 11
denisT.MaxDoctor
I'll let the poorly learned lesson slide this time. But next time, I'll be stricter, and there will be no leniency!
In any case, try to understand how things work and the differences between the previous and final solutions.
Message 11 of 11
rartidiello
Yes! I will definetly check the differences in the solutions! Thanks for the nudge! 🙌
