Accessing Output Color Map rollout of Bitmap
I would like to enable Color Map in the Output rollout of bitmaps and then adjust the Color Map curve.
Is this possible with max script?
best,
Walli
According to the documentation, you cannot change the Color Map checkbox, but you can manipulate the curve. Look at TexOutputClass : Material in the MAXScript documentation.
thanks!
sometimes its hard for non scripters to find the right place in the docu.
So if its not possible to enable the checkbox, then I think I have to think about something else.
best,
Walli
I don't think the difficulty in navigating the documentation is exclusive to non-scripters... 🙂
