Announcements
2 questions about modifier.
1. How to change modifier's tangents from smooth(auto,etc.) to step? (not on Max but in code).
2. Modifier's values shows as "??" in Track View(see attachment), but i set their titles in ParamBlock2.
static ParamBlockDesc2 _movebleobject_param_blk ( _movebleobject_params, _T("params"), 0, &_MovebleObjectDesc,
P_AUTO_CONSTRUCT + P_AUTO_UI, PBLOCK_REF,
//rollout
IDD_PANEL, IDS_PARAMS, 0, 0, &shaderDlgProc,
// params
From, _T("frm"), TYPE_INT, P_ANIMATABLE, 0,
p_default, 0,
p_range, 0,15000,
p_ui, TYPE_INTLISTBOX, IDC_COMBO1, 0,
// p_accessor, &myAccessor,
end,
To, _T("t"), TYPE_INT, P_ANIMATABLE, 0,
p_default, 0,
p_range, 0,15000,
p_ui, TYPE_INTLISTBOX, IDC_COMBO2, 0,
end,
Slot, _T("slt"), TYPE_INT, P_ANIMATABLE, 0,
p_default, 0,
p_range, 0,19,
p_ui, TYPE_INTLISTBOX, IDC_COMBO3, 0,
end,
end
What i did wrong?
PAMD76
You can do this for question 2:
In your accessor (myAccessor) just over ride the ::GetLocalName( ReferenceMaker*, ParamID , int ) function...just return a string for the correct paramID that's sent down.
...hope that helps.
Director / Technology Programmer.
Red Wasp Design & Plastic Ant Software
PAMD76
(Question 2)
This is why it's not working by the way...
//rollout
// params
From, _T("frm"), TYPE_INT, P_ANIMATABLE, IDS_MYNAME, <--------------- You need the resource string ID in here.
p_default, 0,
p_range, 0,15000,
...the first solution I gave will work if you need dynamic names.
(Question 2)
//rollout
// params
p_default, 0,
p_range, 0,15000,
thx. it helps.
Any suggestions about my first question ?
