3ds Max Modeling
Welcome to Autodesk’s 3ds Max Forums. Share your knowledge, ask questions, and explore popular 3ds Max modeling topics.
viewport canvas painting artifacts
4 REPLIES 4
552 Views, 4 Replies
I need your help !
I have posted a question on :
http://graphicdesign.stackexchange.com/questions/22434/3ds-max-viewport-canvas-painting-artifacts
Can someone give me any Ideeas about what's going on?
(the mesh is about 10k -15k polys)
Tags (1)
4 REPLIES 4
blakestone
You need to correctly unwrap your model before you attempt to paint on it.
Technical 3D Graphic Artist
Autodesk 3dsMax 2015 - Service Pack 4
in reply to: blakestone
Thank you for your reply . You are right .
But now I am facing another problem . There are too many vertices and it's a hell in the UV unwrapper.  Is there an automated to lay out the vertices so they don't overlap in the bitmap?
try to use Flatten mapping (unwrap uvw editor)
set the spacing to zero.
blakestone
"Flatten Mapping" 3dsMax will automatically attempt to re-unwrap the model which you may not want.
"Pack UV's" sounds like what you're after, this takes all your selected UV's and arranges them within your work area so they do not overlap.
Once you've done this you shouldn't have any troubles painting on your model.
Technology Administrators
