3ds Max Modeling
Welcome to Autodesk’s 3ds Max Forums. Share your knowledge, ask questions, and explore popular 3ds Max modeling topics.
UVW Map Reversed on Back Side
9 REPLIES 9
Message 1 of 10
truckexpert
2937 Views, 9 Replies
How do I apply an image using a UVW map without having it "bleed through" to the back side of the object.
Here is an example. I copied the box to show the back side.
Dave
Peace,
Dave
System Information:
3DS Max 2023 and 2024
Microsoft Windows 11 Pro
Dell Precision 5820
Intel(R) Core(TM) i9-10920X CPU @ 3.50GHz, 3504 Mhz, 12 Core(s), 24 Logical Processor(s)
Display Adapter: NVIDIA RTX A4000
Adapter RAM (1,048,576) bytes
Installed Physical Memory (RAM) 64.0 GB
Total Physical Memory 63.7 GB
Available Physical Memory 45.6 GB
Total Virtual Memory 81.7 GB
Available Virtual Memory 56.5 GB
Page File Space 18.0 GB
9 REPLIES 9
Message 2 of 10
leeminardi
in reply to: truckexpert
One method would be to use a multi-sub object material that has two materials.  Set the ID of the face to receive the image to be different than the other sides.
lee.minardi
Message 3 of 10
truckexpert
in reply to: leeminardi
Thanks mucho! That worked! Smiley Very Happy
Peace,
Dave
System Information:
Dell Precision 5820
Message 4 of 10
truckexpert
That worked, sort of... But I'd like to have the transparent background of the text allow the base material of the object to show through, like applying a decal
Peace,
Dave
System Information:
Dell Precision 5820
Message 5 of 10
leeminardi
You can achieve that by adding a cutout map (opacity map) to the material with the image.  Do you know how to do that?  Can you post the file of the graphic and I can make the cutout map for you.
lee.minardi
Message 6 of 10
Fadhil_Farook
If you're talking of adding decals to your objects, then you can try the Composite map (not to confuse with the Composite Material). This way you can add multiple decals to your object and you get to keep the diffuse texture. Bear in mind that this may require you to either Unwrap UVW, or use UVW maps to properly use decals.
Here's a video tutorial about composite maps:
https://www.youtube.com/watch?v=mhom5CTFlRs
Instead, if you've Unwrapped your UV's, you can watch this Screencast I made for another member a few weeks ago regarding adding decals. (Don't mind the audio quality)
Message 7 of 10
truckexpert
That would be awesome... here's the graphic. Thanks!!!
Peace,
Dave
System Information:
Dell Precision 5820
Message 8 of 10
truckexpert
in reply to: Fadhil_Farook
Great video and tutorial!! Thank you!!!
Peace,
Dave
System Information:
Dell Precision 5820
Message 9 of 10
leeminardi
Here's the cutout map.   Be sure to use the same tile size and other parameters for it as you do for the diffuse map.
lee.minardi
Message 10 of 10
truckexpert
Thanks, lminardigmail
You are awesome!! This helps a lot!
Have a great weekend,
Dave
Peace,
Dave
System Information:
Dell Precision 5820
