I have applied some objects to a cylindrical tank using the CONFORM object creation tool. But I am getting different results from different renderers. Can you help me? See video below.
Thank you!!!
Dave
Thank you!!!
Dave
This is happening because the object is too close to the Cylinder or tank. What you can do is give the decal...i.e the Tag or the name a non-zero depth. You can apply a shell modifier to it and then make the depth slightly higher than zero. That should get rid of overlapping issues.
One more thing, you can remove shadows of the Decal only. This way, you can move the decal plane just a little further away from the tank and then you can also avoid the shadow and overlapping
