Show only
Search instead for
Since the texture you want to use has top and bottom of the hand showing, you should use point-to-point seams technique (or alternatively select the edges and then convert edge selection to seams) to make comparable top and bottom hand UV islands:
The help docs and internet tutorials can provide more detailed step by step if you are unfamiliar like:
