Could anyone advise on the best and easiest way to put such UV mesh(1) for the texture of the hands (2)?
Since the texture you want to use has top and bottom of the hand showing, you should use point-to-point seams technique (or alternatively select the edges and then convert edge selection to seams) to make comparable top and bottom hand UV islands:
The help docs and internet tutorials can provide more detailed step by step if you are unfamiliar like:
