Hey everyone,
I have a question regarding the unwrap modifier.
I have 2 similar objects (with different widths), and I want to add the same image in their outer surface, like the attached example.
(It is important not to change the original image’s size and adjust only the UVWs!)
So if I want to shorten the text of the left object, I have to scale up the UVWs, which are already scaled to the borders of the UV editor.
Ιs there any way to adjust it further, or is it necessary to change the original image?
Thank you in advance.
