3ds Max Modeling
Welcome to Autodesk’s 3ds Max Forums. Share your knowledge, ask questions, and explore popular 3ds Max modeling topics.
tube primitive, radius 1 = radius 2?
4 REPLIES 4
460 Views, 4 Replies
is there a way to create a tube only one unit thickness?
in other words radius 1 = radius 2
when i do set radius 1 = radius 2 it doesnt render correctly
or should i create a circle and extrude it?
Tags (1)
4 REPLIES 4
Daf
A couple of ways come to mind. I wouldn't use a tube for this - you could create and extrude a circle as you mentioned. Or you could create a cylinder, convert to poly, select top/bottom caps and delete. Probably a few other ways - there always are! 🙂
Daf
3DS Max 2020.3
i7-4790 @4GHz • 32GB • GTX 1080/8GB • Windows 7 Pro
don_3259
hi spectrum i have shown picture of polygon method you can check...thanks
Autodesk Student Amassdor
Guest & Visiting Lecturer
Ali Sajjad
thanks guys, that's the info I needed!
don_3259
welcome dear friend we are here for help so be happy Smiley Wink
Ali Sajjad
