is there a way to create a tube only one unit thickness?
in other words radius 1 = radius 2
when i do set radius 1 = radius 2 it doesnt render correctly
or should i create a circle and extrude it?
Solved by don_3259. Go to Solution.
Solved by Daf. Go to Solution.
A couple of ways come to mind. I wouldn't use a tube for this - you could create and extrude a circle as you mentioned. Or you could create a cylinder, convert to poly, select top/bottom caps and delete. Probably a few other ways - there always are! 🙂
Daf
hi spectrum i have shown picture of polygon method you can check...thanks
welcome dear friend we are here for help so be happy
