3ds Max Modeling
Welcome to Autodesk’s 3ds Max Forums. Share your knowledge, ask questions, and explore popular 3ds Max modeling topics.
Trouble with bevel profile on deformed spline
1 REPLY 1
thor98_
267 Views, 1 Reply
Hey, I am trying to use bevel profile on a deformed spline (created from border selection on a deformed terrain).
No matter the amount of "keep lines from crossing" it's glitching out as shown below
Here is the "clean" result, but only achieveable using a flattened spline - which wouldn't work for the project
..and here is the actual expected result, but is made with a flattened spline just to show the general idea
The reason I need to use Bevel Profile is that it stitches overlapping edges - something that isn't possible with Sweep or Loft.
My backup plan is extruding from within Edge sub-object level, but that is both manually intensive and also prone to the same intersecting issues.
I have tried skinning to a flattened spline, with the original deformed spline as morph target but, this creates poor results around the bottom and is also fairly slow at computing.
Hoping someone could help out with this! 😦
Thor Nielsen
3D Generalist
1 REPLY 1
thor98_
in reply to: thor98_
🙂I have decided to work around this issue by:
  1. create a border shape from the deformed terrain
  2. add extrude modifier without cap
  3. add edit poly and flatten top edges in z
  4. 4 in the extrude mod, raise the extrusion until top edges are just above the grassy border
    1. now, deform the mesh a little by...
  5. ring select edges and connect 1 loop
  6. extrude edges outwards, then weld resulting vertices
  7. extrude top border outwards a good bit, but an extrusion width of 0.75m or so, just to give it an indent in the cliff wall
  8. finally flatten the top border in z
  9. pull down in z to be less vertical
  10. create shape from border and add bevel profile, fire it into turbosmooth, set hard edges at borders and use soft selection to help guide a fractal noise modifier to deform the cliff further
Thor Nielsen
3D Generalist
