3ds Max Modeling
Welcome to Autodesk’s 3ds Max Forums. Share your knowledge, ask questions, and explore popular 3ds Max modeling topics.
Subtracting lines from a Geometry
4 REPLIES 4
mattsimecek
253 Views, 4 Replies
i'm looking for some tips or techniques.
i need to subtract the green lines out of this larger geometry. (think groves in a costume). Boolean gives me odd results and also doesn't produce a Quad Mesh.
any insights would be greatly appreciated.
4 REPLIES 4
Sculpt it if you want clean result or try Retopology after boolean.
CiroCardoso3v
in reply to: mattsimecek
You may be able to use Conform to get something close to what you want.
Lead Enviroment Artist @Axis Studios
Arnold Discord Server
Ciro Cardoso
mattsimecek
thanks Ciro,
conform seems good for getting a geo snug to the surface. i'm really looking for a way to cleanly subtract those lines out of the geometry.
Matt
CiroCardoso3v
In that case, you will have to use the booleans along with the retopology modifier. But due to the complexity of your object, this isn't going to be either an easy or quick task. Dimitry's suggestion is another solution you may want to try.
Ciro Cardoso
