Solved by kgokhangurbuz. Go to Solution.
Chris Medeck
See if this helps: video
Hi;
-Select your Spline
-Go to Utilities > Reset XForm > Reset Selected
-Convert to Editable Spline (again, to collapse XForm)
-Apply Extrude
Kind regards;
I tried this after doing the other selection XForm stuff. But it did not work for me. But this has worked thank you thank you.
