3ds Max Modeling
Welcome to Autodesk’s 3ds Max Forums. Share your knowledge, ask questions, and explore popular 3ds Max modeling topics.
How to weld all lines together
3 REPLIES 3
silk.zither
797 Views, 3 Replies
I'm new to 3dsmax. I created several lines within one Editable Spline. These lines should all be connected, as I made sure to use vertex snap. However for some reason, though they are connected, they are not of a single entity. You can see in the second image that the junctions are not joined properly into one single spline. I tried selecting that Vertex and click Weld but nothing happens. How do I fix these junctions so all these splines become one?
3 REPLIES 3
rendermaster
in reply to: silk.zither
you cant weld them
Ronel Katigbak Pabico
3D Generalist / Animator / Renderer/ Graphics Designer
Autodesk Student Ambassador Platinum
YouTube Channel l Linked l Facebook l Blogs
silk.zither
in reply to: rendermaster
So is there no other way to fix those joints to get a single continuous spline rather than separate ones?
silk.zither
Nevermind. I turned it into Editable Poly and fixed it by deleting a few Segment and reconnecting Vertices using the "Connect" button under Geometry.
