3ds Max Modeling
Welcome to Autodesk’s 3ds Max Forums. Share your knowledge, ask questions, and explore popular 3ds Max modeling topics.
Snapping to edge perpendicularly
1 REPLY 1
647 Views, 1 Reply
Hi!
I have a problem. I am modeling some walls and the walls are not perpendicular straight lines, thats why i have a problem. Im modeling the walls off a dwg that Ive made and i want the model to be precise. Because the walls are not perfectly perpendicular and straight im using the box modifier and then editing the vertices. I have the edge and vertex enabled in snap settings and the axis constraints.
The problem i'm having now is if I want to snap a vertex point to the edge of the line from the dwg file. The green point picker thingy does not pick points perpendicular to the actual vertex, but a random point on the line im trying to snap to. Which means the vertices of the box i'm modeling does not actually snap to the dwg line but either somewhere above or below the line. I need the green point picker thingy to go perpendicularly not just the actual model.
I've attached a pdf to illustrate the problem
Thank you in advance for your responses!
1 REPLY 1
PropChad
Not sure if you found a solution yet? Unfortunately, the edge snap doesn't respect Axis Constraints. It will snap to the edge, but closest to where your cursor is, not where the vertex would meet the line. It's useless for the most part and doesn't act like it should.
I came up with a couple solutions, but below is the quickest so far. If I find a better less convoluted way I'll respond to this.
Pull the edge of the wall below that line. Then, using QuickSlice in the Edit Geometry rollout, and turn on snap to vertex, slice to the vertices on that line to cut a edges across your wall. Select the polgyons below these new edges and delete, followed by capping the hole that will now be at the bottom of you wall.
