3ds Max Modeling
Welcome to Autodesk’s 3ds Max Forums. Share your knowledge, ask questions, and explore popular 3ds Max modeling topics.
Shading of the polygons are weird
2 REPLIES 2
497 Views, 2 Replies
Hi everyone!
I faced with a weird shading problem in one of my objects which you can see in the attached picture. When I export the model into Substance painter the same problem appears there. You can download the obj file here (https://drive.google.com/file/d/1qngvlIeAryt9LYzgv2tRHbjrP1v22A2E/view) in case you want to see if you can find the problem. Thank you.
I already tried:
Editnormal (unify, break, reset)
Smooth group has just one group
UVmap is totally ok
2 REPLIES 2
You might want to reset the normals and return them to unspecified state.
  1. Apply an Edit Normals modifier
  2. Got to Normals subobject
  3. Select all normals (Strg+A)
  4. Hit reset.
Edit: Just saw that you tried this already. Please try again since it worked here for me.
Thanks a lot. It seems I used the normal modifier in a wrong way. Following your steps the problem solved. Thanks again.
