How to disable this subdivision that comes by default
I just got a different version of 3ds max (3ds max 2016) that im not used to work with, and i find this surprise problem. when i create any object and i make it editable mesh it subdivided and its a problem when i try to extrude or simple moved vertex of it. can someone aid me, on how to remove this?. thanks.
ps. sorry my english.
miledrizk
Everything in Max is built using triangles, so the dashed edge you're seeing is showing
You how the 4 sided face is made using 2 triangles. This was always the case.
When you move a Vertex you're moving one corner of a triangle actually,
If you want to select the 4 sided face, just go to Polygon Sub-Object level instead
Of Face.
Or just convert the object to an Editable Poly where you don't have the Face sub-object level,
And you'll not see this dashed line.
Unless you have a good reason to work with Editable Mesh, Editable Poly offers better tools for modeling
Geometries.
miledrizk@gmail.com
3DS Max 2025, V-Ray 7
3DS Max user since 2003 (3DS Max 7)
V-Ray user since 2008 (V-Ray 1.47)
blakestone
As mentioned the dashed lines are there to show the triangles used to create the faces in your model. These dashed lines can be shown/hidden by changing the "Edges Only" checkbox in the Object Properties > Display Properties.
Note: This is a per object setting and does not do it globally. You can run a simply script like below which will adjust the setting for all geometry objects in your scene.
for o in geometry do o.allEdges = false
Technical 3D Graphic Artist
Autodesk 3dsMax 2015 - Service Pack 4
